Jan 2, 2019 10:28 AM UTC
Audio waveform not showing visually
Having issues with this since updating to 2019. Basically, after importing a clip into the timeline everything is as it should be (video plays, audio plays) but the audio waveform does not show up until it's played through so I cannot visually see the audio waves unless I play/skip through the whole clip, which obviously makes editing a lot slower.
Attached an example. Image 1 is the clip just imported to the timeline and image 2 is after playing through a few seconds (as you can see the audio only shows up after I've played through the clip and the remaining audio waves are still blank)
Any help would be appreciated!
Using Windows and Adobe Premiere Pro 2019.
Sep 20, 2021 11:25 AM UTC
Another option is to click on the timeline display settings button - it's the wrench icon in this pic.... There you'll see an option to turn the waveforms on or off.
Jan 8, 2020 3:49 PM UTC
It's a year later and this is still happening. I had a waveform, zoomed in once and it disappeared, now nothing is bringing it back. This mainly happens for me when I use nested sequences, but all the other clips in the timeline using the same subsequence are displaying properly. Just not the one I actually need to edit, of course.
Combined with the wacky display errors when you apply an ease to alpha animation, Pr 2020's UX continues to be an adventure.
Aukejantje
Jan 8, 2020 4:41 PM UTC
Go to Preferences > Timeline > Check 'render audio when rendering video'
After that just select the clip and go to Sequence > Render selection.
Hope this works for you as well.
ColtonCM
Oct 24, 2019 6:02 PM UTC
In case anyone wonders in here, I FOUND A FIX. Right-click your audio clip that has no waveform, and click the option that says "Render and Replace." It will spit out the new clip with the audio waveforms in full view. Hope this helps.
owenburgess
Apr 22, 2021 7:03 PM UTC
This solved the issue for me. Thank you so much!
Aukejantje
Oct 21, 2019 11:05 AM UTC
SOLVED: Go to Preferences > Timeline > Check 'render audio when rendering video'
BartonGarrett256
Oct 10, 2019 6:17 PM UTC
Well none of that worked for me-- resetting, etc... What did was first opening the file in Audition and making sub clips there.  At least for the audio only files.
franciss42583703
Oct 4, 2019 3:27 PM UTC
For what its worth I had a simmilar problem and adobe helped find a fix for me. I layed out the steps on my post here.
https://community.adobe.com/t5/Premiere-Pro/Audio-Waveforms-not-appearing-despite-sound/td-p/10647846
ZenGeekDad
Oct 5, 2019 12:50 AM UTC
franciss, Glad to hear it worked for you. It did not for me, hence my 12 Sep 2019 post. Note that just as I wrote it, I manually deleted the cache, outside PrP; I did not just use PrP's delete cache option in program.
ZenGeekDad
Sep 13, 2019 1:04 AM UTC
The "correct" answer here is not.  At least not always.
In my case, the sequnce stopped showing audio waveform after I'd done manual work in the multicam it sources from.  (I manually edit my multicams a lot.  Usually, things behave fine.  But in today's case, the "no waveform" bug occurred.  Oddly, I could not then recreate it in new test sequences, right afterwards, by following the same steps.  So it's more nearly random.)
None of these fixes worked:
  1. Edit > Preferences > Audio: Check "Automatic audio waveform generation"
  2. Select clip in Program Panel, then frommenu: Clip > "Generate Audio Waveform"
  3. Delete media cache database (even manaully outside PrP0; close PrP; reboot PC.
(I also unsuccessfully tried a number of things not listed in this thread, which I'll omit for brevity.)
Which leaves me with THIS WORK-AROUND:
  1. Select audio track in sequence (not in multicam).
  2. Right-click, Render & Replace.   (Creates/imports/replaces with a file of same name + " Extracted".)
  3. In Project panel, go to audio file that you want the sequence to use, and manually add it to your sequence (not to the multicam) under the rendered-replaced audio track, and then sync manually (visually, using a sharp peak of the waveforms; but cross-check by ear to ensure no echo).
  4. Delete the rendered-replaced audio track, leaving just the desired audio track.
  5. PRO: Any future changes to the manually placed audio file (in the sequence) such as refinements made in Audition will show up in the sequence.  Minor CON/FYI: but changes to the audio in the multicam source are now of course being ignored wrt your sequence.
ZenGeekDad
Dec 14, 2019 9:38 PM UTC
I found one other fix.  If you manually edit your multicamera sequences a lot, like I do, then you might at some point unmute audio tracks below you top audio track.  This will consistently flatline your audio peak trace in timelines that point to this multicam sequence.
While I suspect you can fix this by -- as recurringly offered in this thread -- render/replace, I think the cleaner approach is to just mute the audio tracks below the top track in the multicam sequence.  Seems PrP wasn't intended to mix audio tracks within a multicam sequence.
I tend to do all my audio mixing in Audition anyway.  So this update here is just to report that any seeming short-cut -- to mix in a bit of audio in the multicam sequence -- is actually quite problematic, and best avoided.
mattmattmayer
May 10, 2019 10:14 PM UTC
Sometimes, this solution doesn't work. It didn't for me. But then I found another, simple method. tl;dr below. Hope it helps people.
So I have found that you can trick Premiere into make a new .pek file without much effort.
  1. Make sure this checkbox is checked: "Premiere Pro > Preferences > Audio > Automatic audio waveform generation"
  2. In the Premiere timeline, on the clip in question, right-click > Reveal In Finder
  3. In Finder, move the audio clip up in the Finder folder hierarchy
  4. Return to Premiere
  5. The clip should have lost its link to the file and the Link Media dialog box should automatically appear (if it doesn't, right-click > Link Media)
  6. Relink the clip to where it is in its new location
That should be it. Look at the bottom right of your Premiere windows to see if it's automatically generating new waveforms (generally a blue status bar). Wait till that bar is complete and tada: waveforms. They should show up immediately and automatically. I think what's happening is that this process disrupts Premiere's link between that file and any previously generated waveform information. So the incomplete or corrupt waveforms are ignored, and new ones are generated for the file in its new location. Moving the files up (as opposed to down or into a new folder in the same place) seems essential to confusing Premiere's automatic relinking process. If you've moved it sideways or down, when you click back over to Premiere from Finder, Premiere seems to be able to find it, and so nothing really happens.
A couple notes from experimentation:
  1. Seems okay to make a new folder, just has to be higher up
  2. This can be done in batches (batch move in Finder, batch relink in Premiere)
  3. Seems also to solve the problem of not being able to see Waveform information up through Multicams
tl;dr
Move the associated audio files in Finder to a higher folder in the hierarchy, then relink in Premiere.
Apr 12, 2019 2:40 PM UTC
The same problem here. I can't see the waveforms not only for audio files but for all files. And part of my project files have them and part not.
I tried to move my cache delete it, enable "place cache files next to original", re-render project. re-render waveforms. Nothing helped me, only zoom in the sequence window show waveforms but when you zoom out you can't see the waveforms again.
Really stupid bug and it's sad that Adobe isn't fixing this fast.
digividkid
Apr 9, 2019 10:43 PM UTC
We have had this same issue on and off for the past couple of years. Deleting the .pek and .cfa doesn't work reliably. What does work for us is to delete or move the media cache database. Then close Premiere and reopen. For us, this works every time.
Apr 10, 2019 1:16 PM UTC
Are you moving the folder to a different drive. I tried replacing the folder in didn't work unless I put it on a different drive.
Apr 10, 2019 1:36 PM UTC
BREAKING NEWS!!! For some unknown reason I put my cache files on my original scratch drive the waveforms now work again.
Apr 9, 2019 10:17 PM UTC
Another work around is Render & Replace the audio clips that you are using in the timeline.  Not the best solution, but it does get you a waveform...
Nov 20, 2019 6:55 AM UTC
Thank you so much! This is the only response on this thread, so far, that has actually unblocked me. In my particular case I had a sequence within a sequence which was just showing empty audio. I had to unlink video and audio before I could 'Render & Replace' just the audio element. At least I can work now as I've not got time to debug this on behalf of Adobe.
