Automation in Clip Mixer changing overall level
  • October 11, 2024
  • 12 replies
  • 968 views
Audio automation problem: Dragging a volume fader in the Clip Mixer, in Latch mode, will change the volume before the fade to the final state. There is no possibility to really undo this (undo undoes only the keyframes) except through the Remove Attributes menu. This happens in both Editing and Audio workspaces. Touch mode: same behavior - so doesn't return to previous state after the automation as it should.
Correct answer mstegner
This bug is fixed and you should see the fix in the next beta build.
Hi Kevin,
There are two systems and the bug happens on both:
1. iMac 2019, 6-Core Intel Core i5 (3,7GHz), 64GB RAM with MacOs 12.6.8 (Monterey) and a Sandisk G-drive 18TB (Thunderbolt-3)
2. MacBookPro M2 Max, MacOS Ventura 13.4 working from the internal disk (4TB)
Both run Premiere 24.6.1 (last version).
Formats: MXF video (XAVC-Intra 100 1080p25 and XDCAMHD 4:2:2 1080i50), plus BWF audio (8-10 channel wav). But
Both multicam and non-multicam sequences
To replicate the problem just:
1. enable automation in the Audio Clip Mixer;
2. play the sequence and drag a fader.
Hi @HumbleDaisy,
Can the team have more info? See, How do I write a bug report?
