butaleo
Color changes not displayed in program monitor
  • December 17, 2016
  • 5 replies
  • 11397 views
Hey guys,
When changing colors on video clip on a timeline, program monitor does not preview the changes, however if I tweak colors on a master clip (with Lumetri) source monitor does. Also, when I click export media, preview window is showing the changes. Program monitor seems to be the only one not displaying changes.
p.s. I tried others effects like fast blur, and its working. Colors (fast color corrector, Lumetri) are not working.
what can be the  problem?
Correct answer ramonv62656244
The same happened to me! Just turn off the global FX button!!
Turning off global effect worked for me too!
ramonv62656244
ramonv62656244Correct answer
matha674
This worked! Thank you!!
dlst
found the solution: render your selection and the changes made, even moving forward will show
butaleo
butaleoAuthor
DESCRIPTION OF PROBLEM
When changing colors on video clip on a timeline, progr@@am monitor does not preview the changes, however the changes are made! I can see that in export preview window (in Export Media tab).
In picture below, I tweaked the colors but there is no effect on a program monitor however,
On picture below, I opened Media Export and can see the changes
COMPUTER INFO:
  • OS: Windows 10 Pro
  • Processor: Intel Core i5 760 @2.80GHz
  • Installed memory: 16.0 GB
  • System type: 64-bit Operating System, x64-based processor
  • Graphics Card: GeForce GT440
PROJECT INFO
Premiere Version: 2017.0.01
Footage: Full HD .mov H264 files from T3i
FAILED FIX ATTEMPTS
  • Reinstalled Premiere
  • Tried on other clips with different formats
  • Tried on other projects
  • Tried adjustment layers
  • Cleaned Media Cache Database
butaleo
butaleoAuthor
UPDATE
somebody suggested to turn mercury playback engine to software only.
I did that and it changes are displayed only while am dragging the Lumetri sliders, when you release it, changes are not displayed.
Also, the color bar on the video becomes red, and changes are visible only after rendering.
p.s. I updated my GPU drivers to the latest.
The only thing odd is the first picture.
Premiere is generating peak files.
Might want to wait until that is finished.
butaleo
butaleoAuthor
Thank you, I will take this into consideration, but now unfortunately I cannot edit my post
How about adding the info in a reply....
