Custom Shortcut for Clip Label Color Doesn't Work in Timeline
Issue:
When assigning a custom shortcut to set a clip to a specific label color in Premiere Pro 24.5, using the shortcut in the timeline does not change the label color of the clip. Instead, it shifts the focus to the Project panel.
Steps to Reproduce:
- Open Premiere Pro 24.5.
- Assign a custom keyboard shortcut for setting a clip to a specific label color.
- Select a clip in the timeline.
- Use the custom keyboard shortcut.
Expected Result:
The label color of the selected clip in the timeline should change to the assigned color.
Actual Result:
The label color does not change, and the focus moves to the Project panel.
Additional Information:
- The custom shortcut works as expected when used in the Project panel, changing the clip label color without issue.
- The issue is specific to the timeline.
Cheers,
Paul
