Export Issue: Premiere Pro creates M4V and AAC instead of MP4
- 16 replies
- 2503 views
- Translate
I’ve been encountering an issue in Premiere Pro where, from time to time, exporting my project doesn’t result in a proper MP4 file. Instead, I end up with separate M4V and AAC files, along with a small MP4 file that contains audio only. This happens randomly and seems inconsistent—sometimes it takes three or four export attempts before it finally works as intended.
This is not only frustrating but also quite time-consuming, especially when working on tight deadlines. I’ve double-checked my export settings, and everything seems to be set up correctly. I primarily export using the H.264 preset and haven’t made any unusual customizations.
Has anyone else experienced this issue? Are there any reliable workarounds or solutions I might not have considered? I’d appreciate any tips or insights from the community!
Premiere Pro 2025 (25.0.0)
My render settings are "Mercury Playback Engine GPU Acceleration (CUDA)."
RAM available for Premiere Pro: 52 GB
I'm using Windows 11 64-bit.
About my hardware:
- AMD Ryzen 9 5900X 12-Core
- 64 GB RAM
- NVIDIA GeForce RTX 3060
Thanks in advance!
Sven
