Adobe Employee
Oct 22, 2020 2:12 PM UTC
FAQ: How to solve issues related to undocked panels in Premiere Pro v14.5?
Update: This issue is being addressed in our Beta releases and will be available in a future stable release. You may download the Beta build from the Creative Cloud Desktop app. Please refer to this link to know more about Beta apps.
We are investigating an issue with Premiere Pro v14.5 wherein undocking panels or splitting workspace across multiple monitors might cause a few features to not work.
These are:
  • Keyboard shortcuts not working.
  • Drag & Drop functionality not working for the clips on the timeline.
  • In a few cases moving media clips to a different track on the timeline causes the media/asset to get duplicated in the project bin.
Workaround to fix these issues is to dock the panels or use any of the default Workspaces under the menu Window > Workspaces. If you have modified any of the default workspace, you may reset it under Window > Workspaces > Reset to Saved Layout.
Hope it helps.
Dominic WitherowCorrect answer
Oct 26, 2020 5:08 PM UTC
Ditto exactly!
My setup has 2 monitors to work within and a third to monitor at full resolution. 'Delete/Clear' buttons not working, dragging anything in the Project panel not working. All fixed by switching to an Adobe preset workspace and then switching back to my custom workspace.
MacbookPro 16" 2019, 2.3GHz, 8 core i9, 64GB RAM, AMD 5500M 8GB, OSX 10.15.7 operating in closed clamshell mode with monitors attached via OWC Thunderbolt 3 Pro Dock and OWC Thunderbolt 3 Standard Dock
Professional film maker/editor since 2004, working on MBP M4 Max 128GB, 4TB SSD
Jun 5, 2023 7:05 PM UTC
I still have multiple users reporting issue in v22.2 and v23.0. Has this been fixed or a better way to resolve it?
joshuavik
Nov 17, 2022 6:30 PM UTC
Thank you. I would only add that the better fix is to temporarily select one of the default workspaces. Once you have selected one of the default workspaces, the functionality is restored, and it keeps working even if you then go back to a custom workspace. Docking also restores the functionality but only as long as the Project panel remains docked – if you then undock it again, the fix does not stick. (iMac Pro 2017, macOS Ventura 13.01)
Nov 3, 2022 11:47 AM UTC
For me it still doesn't even if I restore it to default. Idk if it has something to do with it, but I recently changed my keyboard distribution to english one (I've been using spanish one for my entire life, basically), but it kinda makes no sense. So I don't know what to do
Nov 3, 2022 12:24 PM UTC
Try to reset the workspace if it does not work quit the application and clear Preference by pressing the alt or opt key while launching. What version you're using?
Oct 26, 2022 1:32 PM UTC
Just want to mention 2 years later from orginal post and this is still an issue. Changing to a default workspace and then back to my custom workspace does resolve issue.
Oct 4, 2022 8:24 PM UTC
This problem is still in 22.6.1. I can't drag and drop into Project Window bins unless i change my workspace back to undocked and then switch to my normal undocked 2 monitor solution. So annoying.
Oct 4, 2022 8:25 PM UTC
oops. i meant i switch to docked on a single screen and then back to undocked on two screens.
pete_polygon
Sep 7, 2022 9:09 PM UTC
I'm using Pro 2022 and this trick didnt work unfortunately. No hotkeys work at all.
pete_polygon
Sep 7, 2022 9:21 PM UTC
Proxy server is already off, Premiere hotkeys still wont work unfortunately 😞 this is so silly and annoying
Sep 26, 2021 10:31 PM UTC
It's been a year since you said this would be fixed. I'm currently using build 15.4 and I'm still having this problem. Keyboard shortcuts aren't working.
It doesn't matter If I use a preset workspace that I didn't alter. It doesn't matter if I duplicate the sequence. Restarting the program doesn't help.
Every other day I encounter a new bug with Premiere, and spend hours trying to fix it, or find workarounds. I'm exhausted, Adobe.
What would it take for you to dedicate your resources to building a stable program that delivers what it promises? Just make the features you've created work. That's all I ask.
Sep 27, 2021 12:16 AM UTC
Hi lsybela,
Is this a problem with a project you updated from 14.x to 15.x? If so, can you try a new project? Same behavior?
Sep 27, 2021 3:37 AM UTC
I had the Drag and Drop Problem for more than a year. It had to do with windows update. Also, I could not get my Creative Clouds Updates, and later I found out everytime i get a new windows update, Windows LAN Area Network settings automaticlly goes to use a proxy server for LAN, which is BAD. Here is the screen-shot to correct your Local Area Network (LAN) Settings. I dont know if this is going to solve the premiere issue, but for sure it solves the Creative Clouds getting updates.
Also,Try going to the main folder of adobe premier and right click on the premier pro icon and go to compatibility and uncheck the box RUN AS ADMINISTRATOR and it may work
Jul 7, 2021 9:32 AM UTC
Thanks
Jun 9, 2021 2:02 AM UTC
guys, i might have just figured it out.
i was having the same problem, but suddenly i reminded that early when this started to happen i had set the app to run with administrator privileges because i was getting errors about premiere not being able to acess files or something like that.
when i rolled back this change everything went back to normal.
so, don't run premiere as administrator i guess.
May 19, 2021 7:40 AM UTC
Is this a problem with projects created under a different version of Premiere C rather than workspaces?
In my case - a project created under a previous version of PCC with a workspace split across multiple displays.  None of the shortcuts worked at all.  Resetting workspaces or using default workspaces made not difference.
They started working again when I created a new sequence.  Hope that helps.
(expletive removed by moderator)
