Adobe Employee
Oct 22, 2020 2:12 PM UTC
FAQ: How to solve issues related to undocked panels in Premiere Pro v14.5?
Update: This issue is being addressed in our Beta releases and will be available in a future stable release. You may download the Beta build from the Creative Cloud Desktop app. Please refer to this link to know more about Beta apps.
We are investigating an issue with Premiere Pro v14.5 wherein undocking panels or splitting workspace across multiple monitors might cause a few features to not work.
These are:
  • Keyboard shortcuts not working.
  • Drag & Drop functionality not working for the clips on the timeline.
  • In a few cases moving media clips to a different track on the timeline causes the media/asset to get duplicated in the project bin.
Workaround to fix these issues is to dock the panels or use any of the default Workspaces under the menu Window > Workspaces. If you have modified any of the default workspace, you may reset it under Window > Workspaces > Reset to Saved Layout.
Hope it helps.
Dominic WitherowCorrect answer
Oct 26, 2020 5:08 PM UTC
Ditto exactly!
My setup has 2 monitors to work within and a third to monitor at full resolution. 'Delete/Clear' buttons not working, dragging anything in the Project panel not working. All fixed by switching to an Adobe preset workspace and then switching back to my custom workspace.
MacbookPro 16" 2019, 2.3GHz, 8 core i9, 64GB RAM, AMD 5500M 8GB, OSX 10.15.7 operating in closed clamshell mode with monitors attached via OWC Thunderbolt 3 Pro Dock and OWC Thunderbolt 3 Standard Dock
Professional film maker/editor since 2004, working on MBP M4 Max 128GB, 4TB SSD
Nov 11, 2020 7:43 PM UTC
I have a same Issue. I can not Drag, and Drop any Video, Sound, Image Into Premiere, Audition, and After Effects. I wanted to Install the Beta Version from the Creative Cloud App, But It shows Not Compatibel. If I want to Drag and Drop, I see a Circle Error Looking Icon.
Nov 11, 2020 9:16 AM UTC
Are we ok to open projects started in 14.5.0 in latest Premiere Beta and then subsequently take it into a future stable version of regular Premiere Pro?
Harry
Nov 10, 2020 6:51 PM UTC
When is it going to be resolved???? After more than an hour of hard work, I managed to get in here.
Stefan_Gallego
Nov 9, 2020 7:00 AM UTC
This is terrible. How the duck could this pass quality assurance?
@Adobe can't you deliver a bug fix update? I don't mind if the patch is 2 GB 😂
Using AE since 2004
Nov 8, 2020 10:45 AM UTC
This problem is still happening. I'm in the middle of a project which needs to be delivered on Wednesday and I can't work because of all the problems it has. This is just not good enough. You should only release an update which is stable. And i can't even open it in an older version. VERY ANNOYED!!!!
Nov 8, 2020 11:04 AM UTC
Of course it's still happening if you're on 14.5 - it's fixed in the beta but as far as I know, hasn't been released in an update yet.
simple solution - roll back to the previous version.
Paul.
carlosr84258004
Nov 6, 2020 8:06 PM UTC
This problem has made this version of Premiere unusable for me.
Glad it's being addressed.
Nov 6, 2020 2:27 PM UTC
I've literally been driving myself nuts with this for the entire week.
Bobby Broadway
Nov 4, 2020 4:47 PM UTC
I have to say it's pretty unacceptable answer. I have to reset my preferences everyday or work in a window format that I do not work in. I have been an editor for 15 years and you do not have an idea when your are going to fix this. shame on you adobe. No hatorade just frustrated editor. Workflow is everything. Godspeed.
Nov 4, 2020 4:52 PM UTC
It's a really simple fix -
a) Don't upgrade until you know it's stable version
b) roll back to the previous version until 14.6 is released.
Paul.
Bobby Broadway
Nov 4, 2020 5:01 PM UTC
I already did that. Just want them to resolve it and somehow my automatic updates was reset.
Cheers.
TGFX
Nov 4, 2020 2:21 PM UTC
How I wish I could bill Adobe for the hours I've spent dealing with and working around their buggy software. They would be one of my biggest clients.
Nov 4, 2020 4:43 AM UTC
I'm sorry to say this but a much better workaround is to wait for a new, less buggy version of 14.5. I'm sticking with 14.4, which works brilliantly, without all these annoying bugs.
