Adobe Employee
Apr 15, 2020 11:20 AM UTC
FAQ: How to solve low-level exception error after updating to Premiere Pro 14.1?
Update: Solution: Update to Premiere Pro 14.2
Need to remain on 14.0? You may install Premiere Pro 14.0.4 from Creative Cloud Desktop app to continue using Legacy Titles with GPU Accelerated Renderer. Here is how to download the previous version of Premiere Pro.
We have identified that using GPU Accelerated Renderer might cause a low-level exception error to appear in Premiere Pro 14.1.
These errors might appear:
  1. While using Auto Reframe with the nested clip option. Auto reframe works fine, so you can simply ignore these errors.
  2. While using the Legacy title. To workaround this issue navigate to File > Project Settings > General and set the Renderer to Mercury Playback Engine Software Only.
  3. While playing back the media (A low-level exception occurred in: Adobe Player (Player:5)).
    In this case, try clearing the media cache and check if it's working properly. If you are still experiencing the error, switch the Renderer to Mercury Playback Engine Software Only.
Hope this helps in solving the issue. Let us know if you have any questions. To know more about the known issues you may refer to this link.
Sumeet
Apr 18, 2020 6:19 AM UTC
Oh, my God. Thank you. You're a genius, you're a genius, you're a genius, you're a genius. thx
milosh9k
Apr 17, 2020 3:54 PM UTC
I upgraded last night and after that all critical projects I worked on were crashing, so it was great to find out that I can easily reinstall the 14.0.4. Switching to Software Only to resolve the issue is not feasible for my projects, even if it worked.
Well, my problems did not end here. I found out that the new Adobe Media Encoder was taking hours on a file that usually takes about an hour to export, so I had to downgrade it too. Guess what was the next problem - I lost all my predefined export settings ...
Apr 15, 2020 9:52 PM UTC
Another >>>QUICK<<< Fix is to Uninstall 14.1, and downgrade back to 14.0.4
Had the same issue as everyone else, with a legacy Title. . . had to crash our whole daily workflow with Software Rendering, and it was not fast.
michelleg93789222
Apr 16, 2020 9:31 AM UTC
How do I convert my project made in the newer version to be seen in this older version?
Apr 15, 2020 9:46 PM UTC
So the only fix... is to just not use GPU acceleration and accept significantly lower performance during playback? Wow.
Having the same issue with no nesting, no effects, no legacy titles, just editing with a single MOV proxy and a single music track. I've come to terms with the always-kinda-buggy nature of Premiere but this is absurd. No choice but to revert to 14.0.1 (because, of course, 14.0.3 was also giving me inexplicable errors)
tracyo48810966
Apr 15, 2020 9:17 PM UTC
Switch the software render from GPU Acceleration (CUDA) to playback software only. Then try scrubbing through your timeline or editing the squence to see if playback works.
I swithed from GPU to playback software and then back to CUDA and it seems to work. I still get the low-level exception error notification but at least I can see what tf I'm editing now.
Also I've had some luck with duplicating the sequence that you're working on to get playback as well
Apr 15, 2020 8:52 PM UTC
Yup, I'm having the same problem. Going back down to the previous version now, because the "Software Only" switch slows down my whole computer massively. Kind of insane a bug this massive wasn't noticed before release.
Edit: Downgrading back to 14.0.4 from Creative Cloud fixed the issue, and is a way better solution than the one pinned here.
tracyo48810966
Apr 15, 2020 9:16 PM UTC
Apr 15, 2020 8:15 PM UTC
Great... clearing the media cache did not work.  Switching to Mercury Playback Engine Software Only worked, in that I was able to get the media files to load, but it takes more than 10x longer to render.
SiriChandKaur
Apr 18, 2020 2:25 PM UTC
I had this exact same issue. 12 hours to render a 5 minute video! I switched back to previous version and rendered in 5 minutes and did not have to change the Mercury settings.
michelleg93789222
Apr 15, 2020 8:13 PM UTC
I started having this problem after I built a legacy title in my project. I've cleared the cache and changed the preferences, but the After Effects files I've brought in are now "missing/offline."  I have many small icon animations in my timeline that I then customized in Premiere. How can I link them again without redoing the work?
Apr 15, 2020 6:27 PM UTC
I'm having the same issues, but I get the error message when playing back ProRes422LT media in multicam sequences. Both the individual and multicam clips play properly, but those clips within a sequence will only play when the renderer is set to the CPU rather than GPU. (Resetting preferences and clearing the media cache make no difference.) When I uninstall 14.1 and revert to 14.0.4 everything works nominally.
Intel i9-7980XE on MSI Gaming Pro Carbon, 64GB RAM, Samsung 960PRO X 2 (One system & programs, one media.)
NVIDIA GTX1080Ti X 2
Studio drivers: 442.19 (02/03/2020)
dsienko
Apr 15, 2020 6:14 PM UTC
I'm having the same error, but I'm not doing using nested clips.
i7-6920HQ 2.9GHz
Ram 16GB
NVIDIA Quadro M2000M
Video Driver 26.21.14.4274    Dated 3/13/2020
I've cleared cache and changed renderer to Software only.   The video now appears, but so does the error.
