Francis-Crossman17221443
Principal Product Manager
November 25, 2021
FIXED: Export issue for H.264 and HEVC with Premiere Pro 23.1
  • November 25, 2021
  • 35 replies
  • 141984 views
This issue has been fixed in Premiere Pro version 23.2.  Please update to get the fix.
We have identified a file name issue affecting H.264 and HEVC/H.265 exports on Windows with Premiere Pro 23.1
The issue impacts H.264 and HEVC/H.265 exports to folders with names that use double-byte characters, such as Chinese, Japanese, Korean, or extended ASCII characters, like accents and umlauts. Affected users will see this message: File importer detected an inconsistency in the file structure of %filename.mp4%. Reading and writing this file’s metadata (XMP) has been disabled.
If you are experiencing this issue, use one of these options:
  • Please update to version 23.2 where the issue is fixed
  • The following workarounds are for 23.1
    • Choose an export destination folder that uses only single-byte ASCII English characters (no accents, umlauts, etc.)
    • Export to a different format, such as Apple ProRes.
    • For H.264 exports only: disable hardware-accelerated encoding.
Correct answer Ann Bens
Update to 23.2.
Rıfat Dirgenali
When I restored version 23.0 the problem went away
After the latest update I have the same problem. I use H.264. I have plenty of storage space on my harddrive, so that is not the problem. I have changed to Mercury Playback Engine Software Only and use Software Encoding in Export settings. Still doesn't work. I have also tried different Bitrate settings.
The only thing that works for me is when I export to an external drive or even the SD card. Just so you know 🙂
(I live in Sweden.)
December 15, 2022
The workaround is actually disabling hardware-accelerated encoding in the export window. Toggle open the video section and find Performance under Encoding settings.  Change it to Software Encoding.  Hope this helps.
That did not work for me. I restored to version 23.0 and now it works.
Kirmm Ella
The problem I had is that the name of the export folder had non basic English characters. After changing it the problem went away.
December 14, 2022
@10295028, thanks for letting us know this worked for you and you were able to get your project exported.
wsl3825377
after update to 23.1, cannot export file, it shows an error
"File importer detected an inconsistency in the file structure of filename.mp4. Reading and writing this files metadata (XMP) has been disabled."
I need to install old version (23.0) to solve the promlem
Al exportar mi proyecto, aparece este mensaje
El programa de importación de archivos detecto una incoherencia en la estructura del archivo, se bloqueado lectura y escritura de los metadatos
Ayuda!! Como puedo solucionarlo???
when i try to export my proyect this message appears and i cant do it
"File importer detected an inconsistency in the file structure of BBO-tour-00001.mp4. Reading and writing this files metadata (XMP) has been disabled."
please can someone help me fix this!!!
Oh thank you all though i import the Project in a New one with a different name and import first the sequence then the files and it all work out, it took a long while and i had to close every other window in order to let premiere worked perfectly. But the project exported correctly 🙂
i can't. Render any file
kglad
what adobe app?
