Francis-Crossman
Principal Product Manager
Dec 8, 2022 9:20 PM UTC
FIXED Issue: Export mode fails to load in Premiere Pro 23.2 and 23.3
We are aware of an issue that prevents Export mode from loading for some users. When clicking Export in the header bar, a loading spinner is shown, but export mode fails to load.  Selecting File > Export > Media or using the keyboard shortcut Command/Control+M, there is no result; you just stay in Edit mode.  In these situations, exports won’t work in Premiere Pro.  When in this state, Quick Export also fails to function.
This issue is known to affect Premiere Pro versions 23.2 and 23.3 on Mac and Windows.
If you are experiencing this issue, please update to version 23.4 or later to get the fix
If you can't update to 23.4, here are some workarounds to successfully complete your export in 23.3, 23.2:
Workaround #1 – Export with Media Encoder (RECOMMENDED)
  1. Launch Adobe Media Encoder.
  2. Select File > Add Premiere Pro Sequence.
  3. Navigate to your project file on disk and use the subsequent dialog to choose the sequence you want to export.
Workaround #2 – Reset Premiere Pro preferences
  1. Hold the option key while launching Premiere Pro.
  2. Choose Reset Preferences in the “Reset Options” dialog.
  3. Exports will now be successful.
Workaround #3 – Avoid using the “Match sequence preview settings” preset
  1. Do not choose the “Match sequence preview settings” preset in Export mode
  2. Choose another preset such as “Apple ProRes 422 LT” which will make a MOV file and match the sequence resolution, framerate, and preview render format (the same result as choosing Match sequence preview settings) –or– “Match Source - Adaptive High Bitrate” which will make a high-quality MP4 file.
  3. If you use “Match sequence preview settings” once, you will have to reset your preferences to export again successfully.
Our engineers understand the problem well and are currently working on a fix. We’ll update this post when it becomes available.
Francis-Crossman
Francis-CrossmanCorrect answer
May 10, 2023 3:39 PM UTC
This issue is fixed in 23.4, which has just been released.  Update to 23.4 to get this fix.
Apr 30, 2023 1:50 PM UTC
It works, but I have to do it about 10 times a day.
Apr 30, 2023 10:27 AM UTC
Muchas Gracias lo pude solucionar con la 2da opcion!!!
Apr 30, 2023 7:12 AM UTC
The second option works very well, thanks a lot !
Apr 24, 2023 8:29 AM UTC
out of nowhere i cant export my videos. Its just not loading.
When I click on fast export, nothing opens and when I click on export next to import/editing its not loading just the loading circle. i already deleted and reinstalled premiere pro
also I started my laptop again.
Pls help!
When I open the export window or hit Command M, I get a spinning blue wheel that goes on forever. The program doesn't crash, and I can easily go back to "edit," but the Export window never fully opens. I have tried restarting.
I am using a MacBook Pro M1 Max with over 900 gb of free storage.
My external harddrive (which is where my project files are) has 199 gb of space.
Any advice?
MarekMularczyk
Dec 8, 2022 10:40 PM UTC
Have you tried resetting Premiere preferences?
Adobe Community ExpertAdobe Certified Professional
