Pavelito
Footage gets overexposed after importing into project
  • November 10, 2021
  • 8 replies
  • 69653 views
Hey community,
after importing a .MOV file to my premiere project it gets overexposed right away. When I playback the native file in the finder, everything looks alright. Picture one: File on harddrive. Picture two: File in premiere.
No filters are applied on the clip or timeline. I tried importing the footage to a brand new project. Nothing changed.  I even get the same results,  when rendering the clip to my hardrive. I'm using MacOS 12.0.1 (21A559). Premiere is version 22.0.0 Build 169. Working on a MacBook Pro 16" 2019. No external screens are connected. You can download the sample file here https://we.tl/t-8Zy0IQCRzO
I can't edit the video because everything looks burned out.
Thank you all for the support.
Uninstall the latest premiere and use an older version if you need a quick fix while people figure it out. I didn't have the time with my filming and delivery schedule to wait for this process to be completed. Version 2022 doesnt have any exposure issues. ❤️ goodluck everyone technology can be frustrating but there's always a solution! Hang in there! 🙂 Happy Friday!
hello there!! i was having the exact same issues with my footage as well!! i somehow fixed by going into Video Effects>Brightness & Contrast> and then adjusting the brightness and contrast back to a normal level!! i hope this helps!!
What color space is your footage?
What color working space for the sequence?
What is your OS?
donalda26276713
I had the same issue and was able to troubleshoot it.  It's because you are on an intel mac and that and newer versions of Premiere are written for the m1 chip.  It's messed up on Adobe's part that they have not fixed this issue.   Import that same footage into Premiere 2021 and see if that fixes it.  It will.
I had the same problem with Premier 2022, so I switched back to Premier 2021, and it initially fixed it. Now the issue has spread to 2021 as well. Editing that used to take 15 minutes is now taking longer than an hour, because I'm having to make so many color changes to try to match the look of the footage as it was shot. I don't understand why this hasn't been fixed. I never had any similar issues until 2022 was released.
If you're having issues in 2021, they're not the same thing as the color management changes in 2022. Period. The underlying color is COMPLETELY different between the two versions, they don't share anything in color handling.
Which is why bringing 2021 projects into 2022 can have so many issues. Most any log-encoded media that is 'default' handled as Rec.709 in 2021, will be handled as the new default in 2022 as HLG, as HDR. And yea, that makes bringing many projects from 2021 to 2022 a big mess.
But then I don't normally recommend migrating projects forward anywy. Keep working them in the prior version. Install the newer version and use for new projects ... if at all possible.
So if you're having issues in 2021, start a new thread, detail the troubles, and I'll be happy to jump in and help out.
It's very easy to understand why things changed so dramatically in the 2022 version. Very obvious ... they had to change the app to bring the color handling up to modern standards.
2021 and earlier are all hard-coded as Rec.709 underlying color. Which made setting defaults easy for the engineers, and predictable for the users. But that totally limited the app to a Rec.709 'world'.
2022 and forward versions will not make assumptions, so they can work with either Rec.709 or HDR media. Depending on how the users tell Premiere to work with the clip, sequence, and export color.
And that means from now on, users will HAVE to take responsibility to set their color management details for each project.
And understand, I don't think they "stuck the landing" on rolling out the new color system.
We need more contols, more options to set defaults & such. But those will come over time.
Welcome to the modern world ...
dan175424495kzx
Had the same issue with .mov files. So frustrating! I want my video to show up AS SHOT. My quick fix was exporting copys of .mov files through quicktime. In my opion this is a temporary fix & still not exacly right but seems the Codecs & Color profile are the problem! I've worked with lots of .mov files before so idk why this is happening now. Possible monitor problems? but that dosn't seem to be the case. This is a stupid problem. Would love a better solution! Heres screen shots of file info
"As shot" ... that clip is HLG ... an HDR color space. Were you aware of that?
Premiere used to assume a Rec.709 SDR workflow, period. So it essentially 'transformed' most media to Rec.709 (practical explanation). Rec.709/SDR is still by far the most practical mode to work in. Far more screens can handle that than can actually handle any HDR at this point in time.
But as so much media is now HDR of one form or another, like your clip example, they changed because they have to match the media people are working with.
And that means the users now have to take note of and control of color management for clips, sequences, and exports. Which we didn't before because it was all gonna be Rec.709.
Look the the left side screen shot in your post. That clearly shows the clip as in the HLG color space. As I said above, Rec.709/SDR is still a more practical 'space' to work in and export to. So how do you fix this?
You can easily tell Premiere to transform one or more clips from say HLG to Rec.709, but it will not do so unless you tell it to.
So ... select one or more clips in the Project panel/bin. Right-click/Modify/Interpret Footage. Set the option to Override to Rec.709.
Then in your sequence, make sure the sequence settings show a color space of Rec.709. And export with a standard format/preset. The HLG/PQ options all list that in their name.
Signed in just to like your post and thank you for your assistance.
What is the clip? Made or captured by what, and what format?
Pavelito
PavelitoAuthor
It is footage from a Samsung smartphone.
Codec: HEVC
CbCr-Matrix: ITU-R BT.2020
If you go into the color workspace, it would be useful if you could do a screen-grab of the scopes either RGB Parade or Waveform, that would be useful to see. I want to see if the data at the top is showing as clipped.
Then in the Lumetri panel Curves tab, and pull down the top of the RGB curves on the right side. What does that do to the image?
They added both new color management settings for clips in a bin and for sequences plus new default behavior with recognized DSLR log types from some Canon, Sony, and Panasonic cameras especially.
So you have to check what color space the clip is 'seen' as by Pr in the clip properties. And you need to check what color space settings are used on the timeline in the Seqeunce settings dialog.
And as they used the manufacturer's log data as their model, some users (especiallly depending on how they exposed the media in-cam) can get rather bright images to start with from the default normalization.
Pavelito
PavelitoAuthor
Hello Neil, the problem seems to be deeper. The footage is even overexposed when I play it back in the queue monitor before dragging the clip into a sequence.
Averdahl
quote
By @Pavelito
  • Right-click on the media file in the Project panel.
  • Select Modify > Interpret Footage.
  • Under Color Management, set Color Space Override to Rec. 709 & click OK.
FAQ: How to fix saturated/over-exposed HLG clips i... - Adobe Support Community - 12489252
I'm seeing the same thing, with the same specs. Tried a bunch of things with no success.
donalda26276713
