Get Selected Item(s) in Project Panel
Going through the examples and documentation, I couldn't find a function or value to tell if a folder or footage item is selected or access that item in the Project Panel of Premiere Pro. Closest thing I found was .select() which only selects the item you have coded. Has anyone had any success with this? Thanks!
