lindsaym36092399
Nov 25, 2019 7:38 PM UTC
I am having the same problem. Running on a 2017 Mac, Mojave. Didn't run any updates or change anything, this just started happening. None of the fixes I've tried so far are working.
Nov 27, 2019 8:48 AM UTC
Same here. :-(( Tried every solution offered on the internet, youtube, forums, groups, Adobe Tech support, no luck. Loosing time, can't edit. Please, Adobe, FIX this already!!! So frustrating...
I will post if I find the solution.
MacBook Pro (15-inch, 2018)
2.9 GHz 6-Core Intel Core i9
Radeon Pro 560X 4 GB
Intel UHD Graphics 630 1536 MB
Nov 25, 2019 7:32 PM UTC
Bumping to say I experience this as well with Premiere Pro CC 2020 on a mid 2012 Macbook Pro Retina running macOS Catalina
Nov 27, 2019 7:43 PM UTC
Sorry about that, Sam. Could you please upvote here? https://adobe-video.uservoice.com/forums/911233-premiere-pro/suggestions/39076387-bug-premiere-pro-2020
lflegg
Nov 24, 2019 10:09 PM UTC
Same issue here. According to live chat technician, it'll be fixed in early Dec update:
"By the first week of December, we will launch a new patches will be coming on which will fix the issue."
-ASHUTOSH
You can see more of us struggling with it here
https://community.adobe.com/t5/premiere-pro/premiere-pro-cc-2020-crashes-on-fast-forward/m-p/10760292#M238992
Nov 23, 2019 3:59 AM UTC
Farid,
I heard this happens when you are shuttling fast forward. A solution to this issue (for those that have an underpowered GPU) is to choose Project Settings > General and change to Software Only for the Mercury Playback Engine.
If you have a qualified GPU, make sure it has the latest drivers installed. A clean reinstallation may be required. Then you can enable GPU acceleration.
Nov 24, 2019 11:23 PM UTC
just chipping in because I'm having the same problems.
I've just confirmed that a Clean installation of my drivers does not resolve the issue.
I'm currently running an RTX 2060 SUPER, which I doubt could be considered underpowered, and I really don't wish to use Software Only mode because it runs *abysmally* on my system.
Nov 27, 2019 7:42 PM UTC
E,
Can you please upvote this issue? https://adobe-video.uservoice.com/forums/911233-premiere-pro/suggestions/39076387-bug-premiere-pro-2020
I think that would bump up the priority for a fix. The team does know about the issue and a fix is in progress, so that is the good news.
My apologies for this situation.
Nov 23, 2019 3:48 AM UTC
Same problem here.
Nov 27, 2019 7:52 PM UTC
Hey Juan, sorry about this! Looks like a bug. Can you please upvote here? https://adobe-video.uservoice.com/forums/911233-premiere-pro/suggestions/39076387-bug-premiere-pro-2020
I will continue to push for a fix. Let me know if you need guidance on how to move forward. My apologies once more.
Apr 20, 2020 8:00 PM UTC
Hi, I just got my own system with
Model Name: MacBook Pro
  Model Identifier: MacBookPro16,1
  Processor Name: 8-Core Intel Core i9
  Processor Speed: 2.3 GHz
  Number of Processors: 1
  Total Number of Cores: 8
  L2 Cache (per Core): 256 KB
  L3 Cache: 16 MB
  Hyper-Threading Technology: Enabled
  Memory: 16 GB
  Boot ROM Version: 1037.100.362.0.0 (iBridge: 17.16.14281.0.0,0)
  Serial Number (system): C02ZJDSWMD6N
  Hardware UUID: D57D2B42-1A46-525D-9B86-2CC6D4E8EA70
  Activation Lock Status: Enabled
and now I cannot use the graphics card and my system shuts down when I open any adobe cc
Nov 22, 2019 8:19 PM UTC
Really sorry for the issue, Farid. Can I get details around your system, media, and workflow?
Nov 22, 2019 7:50 PM UTC
Same thing here. No solution posted. Thanks for nothing, Adobe! (Again)
Can't roll back to previous Premiere version because then can't open current projects. Thanks for nothing, Adobe (Again)
Nov 22, 2019 8:21 PM UTC
Jordan,
Sorry for the frustration. Can you let me know about your system, media, and workflow, please.
Nov 24, 2019 11:14 PM UTC
G'day Kevin, sorry for the late reply.
My system specs are:
AMD Ryzen 7 3700X
NVIDIA RTX 2060 SUPER
32gb RAM
I tend to work with AVCHD video.
Peru Bob
Nov 20, 2019 12:30 AM UTC
Try updating or rolling back your graphics driver directly from the video card manufacturer’s site.
Nov 21, 2019 2:37 AM UTC
G'day Peru Bob,
Funny you should say - An update just came out for the NVIDIA Studio driver (441.28) but the problem persists. I had the same problem with the previous version, and I'm not convinced using an even older version would solve anything.
I have, however, rolled back Premiere to version 13.1.5, and this version of Premiere works fine.
lflegg
Nov 24, 2019 8:31 PM UTC
same here. Unfortunately Premiere doesn't make it easy to open v14 projects in earlier versions. so that's another nightmare.
Nov 20, 2019 12:06 AM UTC
Bumping this thread because I've been having the same problem.
Nov 22, 2019 8:20 PM UTC
E,
Give details of your system, media, and workflow, please.
