Help! How to make transition fade even color when an item is cropped on white background
  • September 18, 2020
  • 11 replies
  • 1189 views
I'm trying to transition a cropped item on a white background to another clip.  Every time I do it, you can clearly see the cropped area. When you view the clip it's matching and looks like it's not cropped.  But the moment you transition you see the cropped and background transition differently.
Correct answer Christian.Z
This is normal behavior. Cropping does not "cancel" the fact that your first clip has a background, even if this background is white. For this to work, your clip had to be alpha channel, or in case of an image should have a transparent background.
However, an easy workaround is to change the opacity mode of the clip to "Darken"
Peru Bob
Please post a screenshot of your timeline:
