解決済み
Help! How to make transition fade even color when an item is cropped on white background
  • September 18, 2020
  • 返信数 11.
  • 1189 ビュー
I'm trying to transition a cropped item on a white background to another clip.  Every time I do it, you can clearly see the cropped area. When you view the clip it's matching and looks like it's not cropped.  But the moment you transition you see the cropped and background transition differently.
このトピックへの返信は締め切られました。
解決に役立った回答 Christian.Z
This is normal behavior. Cropping does not "cancel" the fact that your first clip has a background, even if this background is white. For this to work, your clip had to be alpha channel, or in case of an image should have a transparent background.
However, an easy workaround is to change the opacity mode of the clip to "Darken"
返信数 11
Did you try to right click on that image from the Project Panel,
then click on Modify - Interpret Footage and choose Conform Alpha to Premultiplied?
Are all the 'whites' your using all the same level? Could it be that some are coming out of clipping earlier than others during the fade. Looking at the luma scope might give you a clue.
Sanmei5FFB作成者
Hi Richard,
I'm not sure how to fix that, since when I adjust the level the color looks the same in the transition frame.  but here is the Luma scope maybe you can tell me what I can do. Thanks!
Sanmei5FFB作成者
Once I rendered it in aftereffects using RGB+Alpha the luma scopes changed and it works now.  Wish it could just have been done in Premiere all at once tho.  Thanks.  Here is a screenshot:
MyerPj
First, you are speaking of a 'mask' and not a crop I take it - due to the shape of the mask/crop.
I couldn't get it to work using 'Darken'
I did get it to work I believe like so.
Nest the clip with the mask and put in a white background on it in the nest.
Then it should work. here it is with the problem:
And without:
And the nested sequence:
MyerPj
Suddenly I can't edit my posts... this is the picture I meant for the Nest:
The WhiteBackground.png is the screenshot of your product with the mask
Christian.Z
Christian.ZCommunity Expert解決!
Sanmei5FFB作成者
Hi Christian,
I didn't get it to work by using Darken as the blended model.  Let me clarify how I did my shot.  I used the "crop" effects and I masked it. Then I inverted and cropped on of side 100%.  I had tried to just use the Opacity and mask it and it didn't work either.  Btw the next clip is a black background. So you can see the mask outline clearly below.  I just want to fade the first clip that has a white background smoothly/evenly to the black background.
Peru Bob
Try keyfaming opacity instead of using the cross dissolve transition.
Sanmei5FFB作成者
Hi Peru,
i tried keying the opacity as well. No luck.
please check your renderer from project settings:
are you on GPU acceleration or software only? try to switch
Sanmei5FFB作成者
Hi Carlos,
I switch it to GPU acceleration and software only.  Still doesn't fix it.
Why is the background cropped. Does it not need to fill the entire frame?
Nest the two images then apply transition.
Sanmei5FFB作成者
Hi Ann,
I tried nesting it.  It still doesn't work.  I also just render out the nest sequence and imported that clip and it will still show the cropped area.
Peru Bob
Try unchecking Composite in linear color in the sequence settings.
Sanmei5FFB作成者
Hi Peru,
I tried the unchecking linear.  It still doesn't fix it.  You can see the crop area still.  Here is the screen shot:
Peru Bob
Try pressing enter to render the timeline and turn the red bar above the timeline to green.
Sanmei5FFB作成者
Hi Peru,
I did that.  I also exporting it.  I tried nesting it. And you can clearly see the outline of the crop area still.  Here is the render screen shot:
Sanmei5FFB作成者
