How do I break up a single sequence project in progress into several sequences?
I have not previously separated a project into several sequences. After starting a large project with a single sequence, I would like to break it up into several manageable sequences. The original clips in the project have been significantly edited, including transition, stabilize, and mocha remove Effects, between clips, with more work needed. This also includes transcoding to use AVCHD with mocha Pro 4. Tutorials show sequences developed from original clips.
To avoid wasting time in a trial and error exercise, how should I break the current project into sequences if possible?
