How mark out point in sequence at playhead
- October 22, 2020
- 6 replies
- 5896 views
Keyboard shortcuts ... "Go to selected clip end" in Application. Or simply type 'go to' and scroll down to get to it.
Mine is set to Shift-End.
This takes you to the last frame of the selected clip. NOT the first frame of the next clip. So it does what you want. I can hit Shift-End to get to that last frame, hit O, and the outpoint is properly set.
