how to align images in premiere pro 2025
  • November 14, 2024
  • 9709 views
You cannot bring in graphics from your bins and drag them over for the align option to show up. You need to bring them in from:
1. Graphics and Titles
2. New Layer
3. Select one of the options, I selected 'From File...' to find my PNG's in my folder
4. Select more than one graphic and the 'Align and Transform' option will show up in the 'Properties' panel
5. Select the 'align' option needed and you should be GTG
quote
By @daphne_2000
That is when you use the Snap in Program feature (those red lines) to align the images.
Dont need to put your png in a graphic clip
Or if they are graphics you can use the blue Guides.
Not a solution
maksh95923910
To align images in Premiere Pro 2025:
  1. Select the image in the timeline.
  2. Use the Position controls in the Effect Controls panel.
  3. Enable Safe Margins or guides for reference.
  4. Use align tools in the Essential Graphics panel for precision.
I create what you see & hear.
@maksh95923910
There is no Ess Graphics Panel in 2025 anymore!!
Its now Properties and GraphicsTtemplates
New Properties Panel in Premiere Pro 25.0 - Adobe Community
In my experience the allignment tools that are accesible when handling text in Properties, doesn't appear as soon as you want to allign graphics like a png-logo. In Essential Graphics (before 2025 version) the tools were the same for both texts and graphics. To me Properties is a downgrade from Essential Graphics, because I now have to calculate where the center is.
Peru Bob
It's in the new Properties Panel.
https://www.youtube.com/watch?v=IIc6smVHnno
i need align multiple images..this video doesn't show that
Use the Snap in Program Monitor feature to align separate images.
