How to import OBS MP4 multitrack audio clip
  • March 14, 2025
  • 2387 views
I used to be able to do this a couple of years ago but now I can't seem to make it work. These clips can be imported to the project but creating a new sequence from the clip only shows the first of four stereo tracks. In regard to modify > audio channels, I have tried every setting there is but nothing seems to work. The closest I have come is to have four audio tracks created, but they are all track one. I have verified the integrity of the clip by playing it in VLC player which revealed all four audio tracks. I have not been able to find any YouTube tutorials that address this issue completely. Any help would be greatly appreciated.
Correct answer Stanley Arthur
I figured it out.
The problem: I was using Premiere Pro
The solution: Davinci Resolve
I installed it for the first time. I opened it, chose the editing workspace, imported the MKV clip and placed it in a sequence. Done. No settings changes. No hassle. No remuxing. No hours of endless trying this, that, and the other thing. It just works. I am a 25-year PPro user (since it was Cool Edit Pro). Why is Adobe struggling so hard to adapt to the changing times? This seems so simple. And now I'll need to make a video about this. The truly insane thing to me is that this used to work in PPro a couple of years ago. I *think* I recall making a minor adjustment in "Modify > Audio Channels" to accomodate this type of file (after remuxing to MP4 from MKV), but it simply does not work now. I'll keep an open mind if anyone can solve this one in PPro. In the meantime, Davinci Resolve works right outta the box.
MyerPj
quote
Cool Edit Pro
By @Stanley Arthur
I believe that was a basis for Adobe Audition.
You are correct. Adobe acquired ReelTime before Premiere was launched. I can't remember what I was editing video with before Premiere.
Stanley ArthurAuthorCorrect answer
I figured it out.
You will have to use beta 25.3 to have support for MKV (which you did not mention the first time) multitrack.
https://community.adobe.com/t5/premiere-pro-beta-discussions/now-in-beta-support-for-h-264-in-mkv/m-p/14961160#M10507
Start reading down from Tom Nord 5 march.
Far, FAR too many problems with betas to ever trust them again, even for 'testing'. Be as it may, if I can drop a multitrack MKV clip into a sequence and it just 'works', that will be a beautiful thing. I'm too old to learn new apllications.
Try Preferences >Timeline > Multichannel Mono Media set to Adaptive before import the file into project.
Thanks but no change or success. BTW, the four tracks are stereo not mono. Do you have any advice on how to navigate the super-unintutive "Modify > Audio Channels"?
