Labels are changing color to default when duplicate a sequence or changing sound balance in mixer
  • June 19, 2024
  • 336 views
Labels are changing colors to default
in a new duplicate of a sequence or if I changing the sound balance in mixer
Hi @Paul Terrie,
Thanks again for the report. A team member could not reproduce your bug. Are you still seeing this issue? Let us know. I'll move your report into the "Discussions" forum while we await your response.
Hello @Paul Tt,
For the information required by engineering, see: How do I write a bug report?
I updated the status of your bug report. Thank you for making it. Please work with the team member on the case.
I hope this will be fixed for you soon.
Cheers,
Todd_Reeder
hi @Paul Tt,  I am not seeing this, can you please provide more detailed steps?  Also what version and build of premiere pro are you running?  What OS?
Thanks
