질문
Linhas Verticais estranhas durante edição! / Strange vertical lines appearing in premiere
  • January 21, 2024
  • 2 답변들
  • 335 조회
Olá, pessoal
Recentemente adquiri um dell g15 e me deparei com um detalhe na reproducação do vídeo: linhas brancas verticais ao na borda do reprodutor. Voces ja passaram por isso? Sabem como solucionar? Grato!
Hey guys
I recently purchased a Dell G15 and I came across a detail when playing the video: vertical white lines on the edge of the player. Have you ever been through this? Do you know how to solve it? Thanks!
이 주제는 답변이 닫혔습니다.
2 답변
did you try to update your graphics driver to the latest 'Studio' drivers?
No, I only use Geforce Experience. is there a difference?
You do not need geforce experience.
Go to the Nvidia site and download the current Studio Driver and do a clean install manually.
Thanks! I Will try!
