StickyQuestion
Looking for VFR (Variable Frame Rate) Problem Files – Help Us Improve Premiere's Editing Experience
  • February 19, 2026
  • 24 replies
  • 1016 views
Hi everyone!
I’m a Product Manager on the Premiere team working specifically on improving the Variable Frame Rate (VFR) editing experience.
We know VFR footage can introduce issues in real-world workflows, such as sync drift, stuttering playback, unexpected frame duplication, audio misalignment, export mismatches, and other inconsistencies. We’re actively exploring ways to make editing VFR footage in Premiere more predictable and robust, and we need real project files that have caused problems.
If you’ve run into VFR-related issues, I’d greatly appreciate your help.
What we’re looking for
Please PM me with:
  1. A link to the project file and media (Dropbox, Frame.io, or similar works well)
  2. A clear description of the issue
  3. Reproducible steps if possible (what you did, what you expected, what happened instead)
  4. Your hardware specs (CPU, GPU, RAM, OS version)
  5. Premiere Pro version
Common VFR Sources We’re Investigating
  • Phone footage (iPhone, Android, Samsung, Pixel, etc.)
  • Screen recordings (OBS, XSplit, Loom, Zoom, Teams, etc.)
  • Gameplay captures
  • Webcam recordings
  • Mixed camera workflows where some clips are CFR and others VFR
Even if the issue seems small or inconsistent, it’s valuable to us. Edge cases help us design more resilient behavior.
Thanks in advance to anyone willing to share files and workflows, I'm looking forward to hearing from you!
    Does anyone know the contact information for technical support? Premiere isn't working properly on my computer. I have a project due and Adobe isn't offering any help.
    Peru Bob
    @Clever_mind8bd7
    If you start your own thread with an appropriate title, you may receive the help you need:
    JonesVid
    Ooops above - I did mean CFR not CBR. Typo 😊
    {reply edited by moderator to fix typo}
    JonesVid
    Good initiative.
    I must admit I have not had too many problems with 4KUHD footage from my iPhone 15 Pro (50fps). I do recall a couple of clips but I’m now so pre-conditioned to use Handbrake I’d rather have all footage at CFR.
    I’m editing a project with iPhone 4K footage now so if I come across any troublesome clips will send it over.
    Dear Adobe Team,
    Thank you for looking into this!
    Here's what I have:
    Recently I got a OnePlus 13, and with the original camera app, once I put the rushes into Premiere Pro, they appear glitchy inside the editing panel, but also in the export.
    The only workarounds I found are:
    •⁠  ⁠Using BlackMagic Camera app
    •⁠  ⁠Using Handbrake to réencoder with CFR
    Here are example files:
    VID... .mp4 - video from original camera app
    VID... Export.mp4 - video from original camera app exported in Premiere Pro (you see glitches in the beginning)
    A001... .mp4 - video from BlackMagic camera app
    https://drive.google.com/drive/folders/1ptGplzcgz_ewXwugu-XKxqpyRXQctVRq?usp=sharing
    アドビの方から、マイクロソフトに固定フレームレートのキャプチャーを出来るように
    促してほしい。
    PPやゲームキャプチャー等可変フレームしか出来ないので。
    まずメディアエンコーダーに、固定フレームレートに変換する機能を付けてほしいです。
    ハンドブレーキ等が、会社のセキュリティの関係で入れてもらえないので、そこから始めてほしいです。
    DVR Footage is a big one, security camera video. I don’t have any examples to share but I’ve had to edit stuff that was VBR 8FPS interview rooms.  Best options we found were to real time re-capture them with an external recorder Blackmagic or Atmos.
    NGUYỄN ANH ĐỨC
    https://drive.google.com/drive/folders/1wxFxR3pgm0Z2FKxHEmdp0t9YsVfH5zhX?usp=drive_link
    VIDEO: 4K 60 FPS, IPHONE 17 PROMAX
    Processor    Intel(R) Core(TM) i7-14700KF (3.40 GHz)
    Installed RAM    64.0 GB (63.8 GB usable)
    Graphics card    NVIDIA GeForce RTX 5070 Ti (16 GB)
    NGUYỄN ANH ĐỨC
    I filmed using the Blackmagic Cam app, and I use the latest version of Adobe Premiere Pro. 🎬
    Cathy22724078qvb5
    I’m having this exact issue and tried so many things found online, non of it is working.
    It is phone footage in VFR recording of the Oneplus Nord 5 (and I cannot chage it to CFR).
    Note: the videos are 1-5min long each, so not hours of footage, the final result is between 1-2min max.
    What is happening:
    The video plays normally in VCL player (original file on PC) and on the phone.
    The imported footage in premiere is shaky and shotty, like with a glitch, in pieces visually. The audio plays as normal.
    When put into a timeline, this issue remains.
    When exporting, this issue remains.
    I imported the videos, made a timeline with 1 one them, edited it to the best of my abilities and exported it. In every single step, the issue remained.
    Specs: CPU Intel(R) Core(TM) i9 - 10980HK CPU @ 2.40GHz
    GPU Nvidia GeForce RTX 3080
    RAM: 32 BG
    OS version: Windows 11 Pro
    Premiere version: Premiere Pro 2026 26.2
    What I have tried:
    • I cleared my cache
    • I tried working with proxies
    • I switched processor settings
    • set the preview to ½ and ¼
    • updated premiere pro (04/05/2026)
    • uninstalled an reinstalled
    • started a new project
    • checked for updates on processor (none)
    • Manually set the framerate for the video
    These all did nothing to fix the issue, I ended up editing it in another program (capcut) to be able to finish it.
    I’m happy to provide the link to my projects.
    Until the whole VFR thing can be handled, you could do like many of us who get stuck with the stuff … do a batch conversion in either ShutterEncoder or Handbrake to CFR. Then of course, there are actually the proper number of frames per second those phones didn’t record.
    It will be nice if they can get Premiere able to use the stuff “on the fly”, with all the additional processing load it requires. As when there aren’t actually any frames for a segment of timeline, and the app needs to create them, well, yea, that’s additional processing load.
    Annabelle190
    I’ve been having sync issues with VFR clips lately, especially with long gameplay recordings. It’s great that the team is looking for sample files to improve the editing experience. I can help by uploading some of my problematic footage if you're still collecting data to test the new Premiere updates.
