mc_dec_hevc.dll module fault
  • April 16, 2025
  • 443 views
While working in Premiere or during the import of media files, the program crashes.
In the Event Viewer, I find the following error log:
Faulting application name: Adobe Premiere Pro.exe, version: 25.2.1.2, time stamp: 0x67eec368
Faulting module name: mc_dec_hevc.dll, version: 13.2.0.18471, time stamp: 0x674db43b
Exception code: 0xc0000005
Fault offset: 0x0000000000548341
Faulting process id: 0x2920
Faulting application start time: 0x1DBAE73A53098FE
Faulting application path: C:\Program Files\Adobe\Adobe Premiere Pro 2025\Adobe Premiere Pro.exe
Faulting module path: C:\Users\Public\Documents\AdobeInstalledCodecsTier2\4.0\mc_dec_hevc.dll
Report Id: 49b3e890-def3-4495-b0b8-d6f848a56bf9
Faulting package full name:
Faulting package-relative application ID:
I have already reinstalled both Premiere and my graphics card drivers.
I am currently experiencing the same issue- any updates??
caroline_edits
Hey Jake, sorry for the issue! Are you seeing this when importing footage? Are you importing .HEVC footage?
The first thing I would try would be to uninstall and reinstall Premiere. Here's an article that can show you how to uninstall the app: https://adobe.ly/4716Rm3
Hopefully, when you reinstall it, it will correctly install the HEVC codec and allow you to import your footage. Let us know if this helps!
Caroline
It's actually completely random, just while I'm editing (not importing). I did just overclock my PC and it only started happening after that, so maybe that's related?
Hi @Farhad30410112mcn5,
Sorry you've been experiencing issues. We need a few more details to try to help with the issue. Please see, How do I write a bug report?
What kind of media files are you importing and working with? Are you getting a Crash Report dialogue box? If so, have you sent this report with your email included?
Hope we can help you soon and sorry for the frustration.
Dani
