Det Scholz
질문
MOGRT is invisible after "Restore Unrendered"
  • March 9, 2023
  • 5 답변들
  • 653 조회
After turned the video file back to a MOGRT using "Restore Unrendered" the MOGRT is not visible in the program Monitor. In "Essential Graphcis"-panel all parameters are still editable but I can't see anything. After dragging the MORGT new on the timeline from the project-window this MOGRT work.
The project is edited on different workstations, using Premiere V 23.2 on a Mac Studio with M1 Chip.
이 주제는 답변이 닫혔습니다.
5 답변
jstrawn
The problem in your post sounded different since it id not involve render and replace or restore unrendered. For the problem you reported, I will need to inspect the mogrt.
I'm having a similar (potentially) problem! I've outlined my problem in my own post, but if you have a solution, please let me know!
AnnikaKoenig
That is really strange. I'm a QE on the Mogrt team. I'll send you a PM so we can troubleshoot this a bit.
Det Scholz
Det Scholz작성자
So while all parameters avalaible in Essential-Graphics you are still able to edit the text for example. Using Render & Replace will render a video with the corrected text but you can't preview it.
Indraprasetio
I've also this problem. Try to reset everything but it just left with blank.
