Jun 19, 2018 10:35 PM UTC
P: Eyedropper/Color Picker Not Working in Lumetri Secondary Color Correction in Premiere Pro
When trying to set or add a key color in HSL secondary in Lumetri color in Premiere Pro, nothing happens. I click the eyedropper, then click the color on my image, and no key is set. I can click any color, anywhere, and no mask is created and the HSL sliders don't budge. It is only on rare and random occasions that I can manage to select a color. I have tried selecting a key color in both the Lumetri panel and the effects control panel. Some related posts have suggested this may have to do with having two monitors, however, I've experienced this on systems with both one and two monitors. The eyedropper works better in the RGB curves effect, but there are times when I have the same issue. Any idea why this isn't working? I've been setting my sliders manually, but would really love to use the color picker, which should not be so consistently dysfunctional!
journeyanimationCorrect answer
May 21, 2024 8:33 PM UTC
I know this is an old bug, but recently had this problem, for some reason it wasn´t working when I had zoomed in the main panel, but as soon as I zoomed out, to ¨fit¨ the eyedroppers started working again.
Hope it helps.
SC-Agency
Dec 29, 2023 9:46 PM UTC
Confirming same for us. Can't use white balance tool on secondary attached monitor. Must drag program and source windows to main monitor and sample from the program preview.
Dec 11, 2023 11:36 PM UTC
I think this is related to the overall wonky multi-mointor / dpi-scaling support within Premiere that could really use an overhaul. Been causing me a lot of issues for at least 10 years and this is just one of those bugs.
Dec 11, 2023 11:21 PM UTC
Moved to the bugs forum.
Dec 7, 2023 7:03 PM UTC
Still. Happening.
Mar 17, 2023 12:31 AM UTC
This exact thing has been happening to me. I tried finding a setting or something for an hour before I just shut down premiere and relaunched it. The eye dropper works perfectly now.
Mar 2, 2023 2:33 PM UTC
The same problem occurred to me. However I believe I now know the cause of the problem. Maybe this helps. I was working on two projects at the same time, the first one was busy analyzing the warp stabalizer, and I was color grading on the other. Maybe the problem with the eyedropper happened because the analyzing was running on the background. This error dissapeared as soon as I closed the project where I was doing the stabalization.
Aug 5, 2022 4:32 PM UTC
Hi Folks,
This may be helpful to some of you running into related problems. I've been beating my head against the wall a bit with similar issues (completely unresponsive key colour selection for HSL secondary) as colour's pretty important for my work and found a workaround that seems to be doing the trick.
It appears to me that the HSL key eyedroppers struggle with track/layer interference when making selections. Regardless of whether the target clip is selected (as you would expect, same as with other tools in Premiere Pro and After Effects), any layer or even empty track above the target clip track seems to prevent a selection from being made. I've shown a typical situation here where there's an adjustment layer, a mostly transparent AE comp layer and an empty track above the target footage; eyedropper was unresponsive in the case of Fig.1, works fine so far in Fig.2:
[Fig.1: Original clip position.]
[Fig.2: Clip moved to top layer. Shift+Drag to maintain timeline placement.]
Temporarily dragging the clip to the topmost track, above all else, before making the key colour selection seems to do the trick for me. I can now use the HSL Secondary eyedropper to select my key colour(s).
My current setup: Version 22.5.0 (Build 62) // Windows 10 // i7-9700  // 16GB RAM // Workspace setup with preview panel (sample source) on primary and colour management + timeline on secondary.
I'll be submitting something to the Devs on the feedback forum shortly, just thought I should help folks out here first. I think we'd all expect that if you have the target clip selected (you know, the one you need to select to access the tool and make the change) that it should be looking to sample from that clip, regardless of where it is in the track stack.
Cheers! Hope it helps!
—Chris
Aug 5, 2022 5:02 PM UTC
If you deselected the Track targeting tool in the first image, would that work as well, without moving the clip itself?
As I'll bet this is simply taking the highest targeted track. And yea, shouldn't.
jpope@madstonefilms.biz
May 12, 2021 12:16 AM UTC
Its now June 2021 and I have this issue and have had it for a long time. Please, Please fix this stupid issue. I have tried all these suggestions and it still won't work. I am going to start editing in Resolve from now on, as the issues with Premiere just keep stacking up.
Windows 10
3900x
64gigs of ram
1070 nvidia card
everything is up to date.
Jul 23, 2021 6:04 PM UTC
My dropper wasn't working. I'm on a dual monitor setup with premiere windows in both monitors. I dragged my main window to my second monitor and the eye dropper worked. Main premiere window back on my main monitor and it doesn't work. Hope that helps at little.
Windows 10
3800x
32gb
1060
everything up to date.
Oct 25, 2020 8:47 PM UTC
[SOVED] Same issue. The color picker works again after I plug off my external monitor.
I'm on Windows 10 with latest patches and latest primiere pro.
It seems to be a bug either for Windows or for premiere that it can not pick color when the secondary monitor is plugged in.
I used the extend mode with the secondary monitor.
Jeff Bugbee
Jan 11, 2021 10:06 PM UTC
Do you have Windows Display scaling turned on?
Jul 20, 2020 1:08 AM UTC
Hey, I had the exact same problem, until I disconnected my second monitor and the eyedropper tool suddenly started working again. So if you're using a second monitor, disconnect it and see if the eyedropper selector works.
