Parts of interface blurry
I'm on the newest stable release of Premiere 25.0.0 (Bulid 61).
Parts of the interface (fx toggles and keyframe stopwatches in effects controls) show up blurry as in the example attached. The bottom parts of overscaled stopwatches are also cut as though they could not fit inside the allocated space. Other elements are also blurry, e.g. new item, new bin, find and trash icons in project window as well as track lock icons in the timeline - everything else looks perfectly sharp as other parts of Windows 11 interface.
It's visible both on my laptop's built-in display (2560x1600) as well as external 1080p monitor but it's much more apparent on the lower resolution screen. I use discrete GeForce RTX 4060 graphics with the newest drivers installed. Is it a bug or is there something wrong with my setup? It's hard to imagine that such a graphical glitch could get past the quality checks and into the final version 😉
DominikLnAuthor
Sure thing.
My specs:
AMD Ryzen 7 7840HS w/ Radeon 780M Graphics
NVIDIA GeForce RTX 4060 (566.03 Game Ready Driver)
64GB RAM
2x 2TB SSD
As I mentioned the issue is present both on the laptop's internal 2560x1600 display with 150% scaling as well as external 1080p monitor with 100% scaling.
I have GPU accelerated rendering turned on but frankly I have no idea where to enable/disable hardware accelerated UI.
I installed the newest beta of Premiere and I see that said elements look much better so I guess the issue is still being worked on - keep it up 😉
jamieclarke
Hi @DominikLn  Thanks for submitting your bug report. We need a few more details to try to help with the issue. Please see, How do I write a bug report?
Can you let us know which specific driver version you have as well as computer specs.
Do you see this same behavior in the beta?
Are you using any custom scaling in your OS?
Do you have the setting GPU accelerated UI rendering off or on?
