Possible to (disable) 'Snap' inside Effect Control window for Keyframes?
Using: Premiere Pro 2019
Quick question that I couldn't find an answer to.
Can you disable the keyframes so they don't snap to timeline inside 'Effect Controls' window, as the (S) Snap only affects the project timeline and not inside Effect Controls w/ keyframes.
