daveybuoy
Premiere Pro 14 won't startup in OSX Catalina without deleting a folder every time
  • January 7, 2020
  • 4 replies
  • 2597 views
Ever since I upgraded OSX to Catalina, I have to delete the "14.0" folder from "/Users/x/Documents/Adobe/Premiere Pro" or it won't launch.
How do I make this pain in the butt stop?
Correct answer daveybuoy
Hi everyone.  In case anyone else is struggling with the permissions sinc ethe upgrade to Catalina (as in you didn't give it permission when it prompted you for the downloads, desktop, documents, or removable drives), and you want to change your mind, I figured it out,
Go to your settings, security and privacy, and click on the tab named "privacy" on top.
Select "Files and folders" on the left hand menu and there it all is.  You can select or deselect which applications have which permissions.
daveybuoy
daveybuoyAuthorCorrect answer
When I go into this tab, everything except for Premiere Pro will show up. It doesn't let me allow PP to have folder access and therefore doesn't even let me open PP, because every time I do that it asks me to give it folder permissions, and I can't even do that (running macOS Big Sur)
Bigsur hasn't been released yet. If you expect premiere to run on it you're
making a mistake
you say folder permissions are ok, but you can't always tell if they are actually ok or not.  And these sort of issues are more likely to happen after an OS upgrade.  As Nishu Kush suggested, creating a new user with administrator privileges may help you see if permissions are actually an issue.   It's also sometimes useful to do a complete clean install of the OS and apps.
nishu_kush
Hi @daveybuoy,
Thanks for reaching out. As @mgrenadier mentioned, this could be a permission related issue. Here's how you can change the permissions for the folder: https://support.apple.com/en-in/guide/mac-help/mchlp1203/mac
If that doesn't help then create a new user account with admin rights and check the issue in it.
Let us know how it goes.
Nishu
Have you checked the permissions for the folder?  From the finder, select the folder and hit command-i.  And then go to the bottom of the window for sharing and permissions.   Make sure your active user has full permissions.
daveybuoy
daveybuoyAuthor
The folder permissions are okay, but I do remember after the Catalina update that the system did randomly start asking if premiere could have permissions to different folders and I denied it.
Is there a place I can adjust whatever those prompts were for?  My user has full access but I'm not certian the application does.
