New Participant
July 28, 2021
Premiere Pro 2021 using CPU instead of GPU with CUDA enabled
  • July 28, 2021
  • 2334 views
Hello I have Mercury Playback Engine GPU Acceleration (CUDA) enabled in project settings and hardware encoding for performance in encoding settings, but when I export it takes ~9 hours for a 30 minute 1080p video and in task manager the CPU is at around 90% and GPU is around 2%. Is there any solution for this?
Ive updated drivers and this issue is still present.
Computer Specs:
Ryzen 5 3600x
GeForce RTX 2060
16GB DDR4 Ram
512GB SSD
John T Smith
Not everything uses CUDA - and other hardware acceleration notes
https://community.adobe.com/t5/premiere-pro/faq-all-about-hardware-encoding-in-premiere-pro-14-2/m-p/11150057/thread-id/272665?page=1
https://community.adobe.com/t5/premiere-pro/everything-you-need-to-know-about-gpu-in-premiere-pro/td-p/10751263
https://community.adobe.com/t5/Premiere-Pro/GPU-Rendering-Unavailable/td-p/10726745
Also be sure you have an up to date driver for your 2060
Go to the vendor site to be sure you have an updated driver for your graphic adapter
nVidia Driver Downloads http://www.nvidia.com/Download/index.aspx?lang=en-us
-for Premiere Pro and MAYBE Premiere Elements use the STUDIO driver, not the GAMING driver
-such as (this MAY not be the latest) https://www.nvidia.com/en-us/drivers/results/170344/
If you have a laptop you MAY also need to check for a laptop specific nVidia driver
There are also intermittent reports that the newest driver is not always the best driver due to driver bugs or compatibility issues, so you MAY need to try an earlier driver version
Elvir5C4EAuthor
New Participant
July 28, 2021
I downloaded the studio drivers and it didnt seem to change anything
Brainiac
July 28, 2021
What format/codec are you exporting to?
As noted by John, a lot of things don't use the GPU ... so do you have any color effects, Warp, or any resizing going? If not, then you may not be doing anything that uses the GPU.
Are you using plugins? Try dissabling Nvenc and see what happens.
Elvir5C4EAuthor
New Participant
July 28, 2021
i dont believe im using any plugins , I tried doing software encoding instead of hardware and its the same time around ~9 hours. (I believe this is what u meant by dissabling Nvec)
