Premiere Pro 2023 audio drop after adding a cut between a clip
  • February 2, 2023
  • 267 views
i am using premiere pro 2023 on windows 11 and when ever i add a cut between a clip the audio of  the clip next to the cut drops down and cannot hear anything
Hello @SK00128217385nnsx,
Thanks for the message. Are you still having this issue? The team will need more info from you to reproduce the bug. Can you provide the information in the format required here? How do I write a bug report?
I'll move your post to the Discussions board while we await your information.
i am also having the same issue right now
