Premiere pro 2023 not exporting right PNG frame
When exporting frame (png) from premiere pro, sometimes it doesnt export the frame selected, but some other frame nearby.   Did anyone had this issue and known the solution to solve it ?
Bruce Bullis
Bruce BullisCorrect answer
What timeline range are you setting, when using Custom?
Custom respects the in/out points under the video preview, in Export mode.
Also...if you're exporting a frame as a .png, why not just use the 'export frame' button under the Program monitor?
I feel stupid now. ahah. thanks ... for the real solution.
Stan Jones
Ferdy,
Congratulations for finding a way!
Your "transport controls" are turned off in the Program Monitor.  In the Program Monitor, click the Wrench icon, then pick "Show Transport Controls." I suspect the Camera/export frame icon will be there. If not, you'll also see the plus Bruce refers to.
Stan
still can't figure out how to have the button under program monitor but i managed with shortcut to export frame as if i would use the button. thanks. case closed.
Bruce Bullis
The button editor is displayed when you click the big plus sign, at the bottom right of the Program monitor.
buttons are not under Program monitor ... only under Source monitor
Bruce Bullis
Happy to help!
Bruce Bullis
You can control which buttons are visible under the Program monitor, using the big plus sign at bottom right.
last thing Bruce, the  'export frame' button is not under program monitor but under Source monitor. So, if you apply a color correction on a file in your sequence, you can t open your choosen 'frame'  in source monitor WITH the color correction applied. Can i add button under Program monitor ?
Thnak you Bruce for the follow up. I noticed with your last message my lack of knowledge about that export frame button and i have to acknoledge now that it's the quickiest way indeed to achieve this opeation.   THANK YOU BRUCE
Bruce Bullis
