Premiere pro 2023 not exporting right PNG frame
When exporting frame (png) from premiere pro, sometimes it doesnt export the frame selected, but some other frame nearby.   Did anyone had this issue and known the solution to solve it ?
Bruce Bullis
Bruce BullisCorrect answer
What timeline range are you setting, when using Custom?
Custom respects the in/out points under the video preview, in Export mode.
Also...if you're exporting a frame as a .png, why not just use the 'export frame' button under the Program monitor?
i put custom in the range and i unchek the 'export as sequence'
Bruce Bullis
In the Export tab, what are you specifying for Range?
and also : it is premiere pro 2024 not 2023
you are pretty much right. except for :
move CTI to to time T then EXPORT choose format : PNG
and the export is not time T but some other frame on the same sequence
Bruce Bullis
It hasn't (yet) been reported, but that doesn't mean it's not worth further attention...
Steps to repro:
0 launch PPro
1 open project
2 import some media
3 put media into a sequence
4 move CTI to time T.
5 click the camera button, or hit Shift-E to export frame
6 choose format PNG, export
Result : Frame exported at time T + ??? (some random factor)
Expected: Frame exported at time T.
Do I have that right?
I did reboot and also reset the media cache without any better results
