Premiere Pro 2024.0 Not Transcribing source clips.
  • October 11, 2023
  • 37 replies
  • 23421 views
Premiere Pro 2024.0 Not Transcribing source clips.In the transcript window when you click transcribe it attempts to then fails
Correct answer wcole90
It's working fine now. Thank you
I've uninstalled and reinstalled Adobe Premiere several times today and nothing seems to be working to get the transcription. What might be going on?
Stan Jones
@ac81483736,
Did you follow @Alexander_DVA' instructions in the pinned reply above?
https://community.adobe.com/t5/premiere-pro-discussions/premiere-pro-2024-0-not-transcribing-source-clips/m-p/14147812#M505558
If that doesn't fix it, report back with more info.
Stan
HAYABUSA
SAME HERE! By the way is this on MacOS? or you having this issue on windows?
Sincerely, EL HAYABUSON! 🤣
wcole90Correct answer
Kevin-Monahan
Hi @noah25558464vd62,
Are you still experiencing this issue with the current version of Premiere Pro (24.4.1)? Please let us know.
You need to load the clip in the Source Monitor, then it works perfectly.
Same issue here. The problem started when upgrading to 24 and also tried 24 beta. Still no dice
Workaround:
I'm using v24.0.3 to avoid the morph issues with v24.3. Too get .mxf files to transcribe, I created a new small project in PP 23.6.4 (still installed on my system) and did the transcription easily there. Then I imported the clips into via Media Browser back into the 24.0.3 project with the transcription intact.
Just tried Valentina Vee's tutorial after installing Premiere 2024.0 and even her example clips do not work in clip transcribe mode,  though the same clips are instantly transcribed when you switch over to transcribe sequence mode. The error displayed is No Dialogue Found. This is problematic as the whole point of the tutorial is to learn how to edit with text using Clip Transcribe mode.
Hi, after 10 minutes of the transcribing process, I also get the No Dialogue Found on the newest Premiere Pro version. How did you fix this?
Stan Jones
pakeeza,
Thanks for posting. The file you are trying to transcribe is not .mp4, but a .ts (transport stream). I just tested and was able to transcribe a simple file in both .ts and .mts files. But transport streams come in many flavors, but I suspect that is why it does not complete transcribing as a source clip.
You use the workaround of creating a static transcription of the sequence. That works for clips with single-track audio, and many files that don't have overlapping dialogue on multiple audio tracks, but some of the users in this thread have mxf files that have problems even with static transcription.
Stan
This happened to me, I deselected 'automatically transcribe clips' in preferences and it worked after that.
