解決済み
Premiere Pro: Adding a Custom Preset to Audio Track Mixer
  • February 9, 2025
  • 返信数 2.
  • 534 ビュー
Is there a way to add a custom preset to the audio mixer? I know you can add each individual portion of the preset, but that also seems to be limited to 5.
Premiere Pro V 25.1.0 (Build 73)
Mac M1 Max 64GB Ram OS 15.3
解決に役立った回答 PaulMurphy
Unfortunately, the Audio Track Mixer does not support custom effect presets for track-based effects.
That said, you can copy individual effects along with their settings to other tracks by holding down Alt (Windows) or Option (Mac) and dragging the effect to another track’s effect slot.
Each audio track is limited to five effect slots. However, you can work around this limitation by routing the track to a submix, where you can apply additional effects as needed.
返信数 2
PaulMurphyCommunity Expert解決!
kglad
<"moved from cc desktop">
