Premiere Pro CC 13.0.1 corrupt color problem.
I'm having a color problem while playing the sequence or when randomly jumping from frame to frame in timeline.
I keep jumping from frame to frame till it becomes normal.
It's only a playback issue, it doesn't export movies like this. It also happens sometimes when i change color options in Lumetri.
Sending you a sample frame here.
Thanks.
