Premiere Pro CC 2020 (14.0.1) Encoding Stuck on 0%
  • January 22, 2020
  • 18 replies
  • 66177 views
Hi there,
I'm trying to export a 1080p (24 fps) 90 second video in h264. I've done this hundreds of times before but for some reason the encoding window gets stuck on 0%. This is the first time I've tried to export with the latest update of Premiere Pro 2020 (14.0.1). Here are some quick notes:
(running on Mojave OS)
  • I have cleared media cache
  • I have tried render all previews
  • I have tried exporting in different formats to different locations
  • I have tried exporting through Media Encoder
  • I have not experienced any issues with exporting from this project before. This is the first time encoding in this version of Premiere Pro 2020. Most recent successful export was in Premiere Pro 2019.
Any suggestions are appreciated. Thank you!
Same issue here. Along with the time remapping issues, nesting issues, lumetri issues, etc, I have to wonder why you (adobe) keep pumping out new versions when they're completely rife with bugs, along with old ones that still haven't been fixed.
None of us "here" are staffers or engineers ... so we don't know "why". We've just figured out how to get around it when that specific thing happens.
I have been getting this issue as well,
The easiest fix that worked for me is to create a new sequence and copy everything into it.
What causes this issue though?
Hi there,
We are investigating this issue. You may try the steps mentioned in this article and check if it helps.
Sumeet
Thank you Sumeet -- the recommendation in the article around deleteing the marker_GUID info worked for me.  https://community.adobe.com/t5/premiere-pro/how-to-solve-encoding-export-stuck-at-0-with-premiere-pro-adobe-media-encoder-14-0-1/td-p/10875118
Did not need to do the new sequence / copy paste approach.
For both Hampus and Silver ... were the sequences originally created in the 2019 13.x versions of Premiere?
I have seen a user elsewhere report that some sequences created in the 13.x/2019 builds won't export in 14.0.1. His workaround was to create a new sequence in 14.0.1, copy/paste the contents of the old sequence into the new one created in 14.0.1
You may find it faster to do this by setting up a "pancake" editing screen with two timelines vertically stacked.
Thank you! It worked wonders!
Harold Silva
Hello, apparently you has tried many things before;  What I suggest seriously do the following: Open your project; Now create a new project and copy and paste the timeline on the new project (there may be some error in the project you are currently working on) close the preview project and try to export.
Best regards
Harold Silva B.
Thank you! That was the solution! Worked like a charm!
Silberfarb
I'm having the same problem. I spent a number of hours on tech support. The solution for me was to downgrade to Premiere Pro v14.0.0
im sorry but what editor spends hours with tech support.. I had the same problem and just name a new sequence and copy and pasted everything over and it fixed it.. come on editors! Get scrappy!
It's not about getting scrappy. It's about Adobe making Premiere function. We do not have time to spend hours, as all of us here have done, with tech support. Eveytime there is an update I cringe as I am doing now because of all the new glitches. I really am ready to drop the program all together and migrate over to Resolve.
It's unfathomable. Genuinely. How this program is considered to be in the upper echelon or even top 3 of editing softwares is wind boggling based on how faulty it is, and how erroneous the customer support is. If I could go back in time a year I wouldn't put money into bitcoin or tesla I would just tell myself not to get locked into the year long plan with adobe. Overwhelmingly negative experience. I spend just as much time troubleshooting (maybe more) as I do editing.
