87arya
Premiere Pro CC and missing audio tracks for .mts files
  • November 4, 2013
  • 29 replies
  • 84352 views
Hello guys,
I used to edit my .mts files with Premiere Pro CC without any issues until yesterday.
Now I import my .mts file (made with a Sony VG900) but Premiere doesn't recognize the audio tracks (that I can hear just fine with VLC).
I tried changing the extension in .m2ts but it didn't work, I also tried reinstalling Premiere but, again, it didn't work and I tried (I was desperate) to install Premiere CS6 just to check if maybe the problem was just about the CC version. Guess what? It didn't work...
I tried also converting the file with Encoder in .mp4 but after the conversion I can't hear the audio with VLC and, of course, it doesn't work on Premiere.
Do you think it's a Premiere issue or a file problem?
I used those same files for other videos (like this one http://www.youtube.com/watch?v=H1X5vsZ-5yI) and I had no problems. Then I updated Premiere, I moved the files in other folder and the problem came to life.
Any idea?
(I'm waiting for my colleague to send me a new mts file just to check if I accidentally damanged the old ones).
Correct answer Kevin J. Monahan Jr.
See the solution for issue #1 in this doc: Known issues in Premiere Pro CC 2017 (November 2016)
R42PRO
Its a Easy Fix
After Updating to the latest version adobe Premier Pro CC
There are some changed that take place in your setting.
The media cache location goes to default location so the cache goes missing.
I had set my cache location to SSD : Z drive but after update that all changed to User/ Appdata / roaming / adobe / media cache.
so here is where Premier gets confused and does not reconstruct the cache files cause it looking for the original cache location.
The FIX
delete all the cache files in default location and also cache in folder that you created for cache all media.
Then in the preferences/media set up the new cache location.
now open your project in Premier
It should automatically start rebuilding your cache and
the .MTS file should now show audio wave.
No Need For Uninstall its just a bug. but a easy 10min fix.
lawrenced4390097
I don't know if this helps but I've been having problems with mp4 files, audio missing when I import. when I first open a file it is empty before it makes a sequence. For some reason when I drag a file over when premiere is in this state it sees the audio. So I import all the files I want to use from the media browser, then I select all the mp4 files I want to use and drag it over to the sequence window and it sees the audio. I'm using Windows 8.1. I've never hand this problem before but this the workaround I'm using. Also it works when you copy the sequence, it copies the audio too. This sucks to have to work like this, I'm paying way to much money to have to work like this. Please adobe fix this problem for windows. Thank goodness I'm not doing anything to complex or I would loose my mind.
JohnyFive
what i just ended up doing was, i imported the Video CLip into Adobe Audition and then exported the wav to place into Premiere, worked.
and you were using MTS files?
A whole lot of people are having this issue with MTS... wondering if Sony
and Adobe locked horns somewhere?
m
***LITE Your Bike !!!
Keep the Rubber side down.
Ciao,
mark
"SAVE YOUR Life, Ride ULtra BRIGHT, DAY And night"
.......__o
חזק ואמץ
אין ברירה
Mark D. Goodley
100 Scholz Plaza PH-1
Newport Beach, Ca. 92663
949 642-5242
1112 Canyon Rd. #388,
Fawnskin, Ca. 92333
909 866 -2566
760 213 4958 Cell Phone
markdgoodley@gmail.com <markdgoodley@aol.com> Email
markdgoodley Skype.com Address
TBA Skype Phone to call (if online)
@newportcycling
The information transmitted herein is intended only for the person or
entity to which it is addressed and may contain confidential and/or
privileged material. Any review, retransmission, dissemination or other
use of, or taking of any action in reliance upon, this information by
persons or entities other than the intended recipient is prohibited. If you
received this in error, please notify the sender and delete the material
from all computers. Thank You!
ajamal1
I'm having the same problem here. I have a Macbook Pro and I'm  running adobe CC latest. After renaming some of my mp4 files, and I had to relink them, the audio track did not show on the timeline at all. Even when I play the file from the media browser, it shows the video but the sound does not working at all. This is a big problem because I have a lot of video projects that are affected by this. It would take a lot of time to do the workarounds.
This is terrible. I can't believe it's been two years since people complained here and this issue still has not been resolved.
Thinking to unsubscribe from Adobe.
Hi Ajamal,
Did you follow the directions in this thread? Re: Premiere Pro CC and missing audio tracks for .mts files
I have found a workaround. The problem is still not fixed, but this works for me and my workflow is affected less. I select my clip as shown in the picture. Then I click "Automate to sequence..." (the icon on the bottom I marked). The clip is then inserted at the position of the playhead (marked with arrows) and the audio is linked, visible and can be edited.
I hope this helps, and even more than that, that Adobe fixes this problem for good.
Disclosure, I did use the media browser as well as the CTRL + I function to import my clip and there is no difference. I've had the problem with .mp4 files. They did play in the media browser window, but not when inserted to the timeline.
Where is "Delete audio cache files"...???  Mine only shows "Clean"
DigitalSpatula
I had the same disappearing audio and repeating audio. If you delete the audio cache files (.pek) then it will force a new audio conform and then work fine.
Thank you, DS. That is a helpful tip.
I have found that the #1 cause of this problem is that people do not use the Media Browser to ingest these files (any other method of ingest is not reliable), and they do not wait for the files to conform.
For all on this thread, please read this article in the documentation: Adobe Premiere Pro Help | Importing assets from tapeless formats
If you have followed the directions and are ingesting tapeless formats correctly, then create a new post indicating that you have ingested properly, and have waited for all your files to conform, but are still facing issues.
I still have the same issues... Video only, no audio tracks... when trying to load into Audition, error message states there are no audio tracks...
Windows Player, etc... have no issue playing video/audio together... ONLY Adobe has a problem recognizing .MTS audio files!
Help/TY
June 24, 2015
Moving from FCP to Adobe not long ago and this happened twice. I've tried to revert it back to previous version but it just can't overwrite my current version. Tired up of switching back to FCP everytime...I'm now converting my AVCHD/MTS after reading this mts to mpg article, but still hope Adobe could fix it so I no longer need spend hrs to do the conversion.
FYI I had the same problem...
Everything was fine then I tried to add a gopro file .mp4 into my project and all of a sudden it wouldn't import any audio (mp4 or mts)
The workaround I found was to edit the clip in Audition  from the project files when I did this it created an audio clip i then linked to the video part of the mp4 file.
Hope this helps!
Really?  2 YEARS and this is still isn't fixed?  I'm so tired of constantly dealing with this problem.  Clipwrapping everything and using 2x the data I need to is NOT A SOLUTION.  We shouldn't need workarounds for one of the most basic functions of an editing platform.  If I sound ticked off - I am.
Hi Shamer,
May I ask how you are ingesting your files?
Sigva
I've been having this .MTS audio problem for a while know, and have read a lot of posts about different issues and ways to handle them. Here is a short overview of my experience the last few weeks, but this issue has been bugging me more and more after I started producing a weekly TV show with lots of .MTS files from my Canon C100.
  • I've had missing audio, looping audio and even audio from older files with the same file name, i.e. "00127.MTS" has shown the right video, but played an audio from a file with the same name recorded some weeks earlier (the two files are in different folders on my Media Drive of course).
  • I've cleaned the Cache files: Common/Media Cache, force quit the processes aerendercore and PProHeadless, to be able to empty the trash.
  • I've restarted PrPro, the program has rebuild the Cache...but sometimes that hasn't solved the problem.
  • My recent "brute force workaround" is to manually find the Cache file in the Commons folder, i.e. by searching for "000127". That gives me results like the following: "00127-6c2....ims" - "00127.MTS 48000_1.cfa" - "00127.MTS 48000_1.pek"). I delete those files, offline the clip (00127.MTS) in the project, relink it - and this usually solves the issue. But it's getting more and more time consuming to do this with more and more files.
Could this be a problem with PrPro linking to the right audio files? This could explain why I've been getting audio from older .MTS files with the same name.
If this is the case, I find it strange that the program doesn't have any problem linking to the right video files all the time, but seems to screw up linking to the right audio files.
I hope Adobe can shed a light on this annoying bug, that seems to have been causing a lot of people problems for some time.
Best regards,
Sigva
Mac OS X 10.8.5
PrPro CC 2014 8.2.0 (Build 65)
Same problem. Audio waveforms are gone on a project where they were just at 10 minutes ago. I think it happened because premiere was conforming files when i did a save.
Found a 30 second fix.
Go to the folder containing your original media. Rename it to anything at all.
Go back to premiere where it will immediately say all files are offline.
Go back to the folder and undo/rename the folder back to its original name.
Return to premiere once more and locate one of the offline files. It will reconnect all files and your audio will reappear.
hellopaul4
This totally worked for me! I found that same  solution here, in the comments (not in the video itself): Adobe Premiere CS6 - What to do when your files go offline - YouTube
So to recep - just rename the folder(s) containing the offending clips, load up your project, then reconnect, and your audio is restored!
