Premiere Pro Constantly Saving After Every Cut with Ripple Delete - Need Help Fixing the Issue
- March 18, 2023
- 1 reply
- 278 views
I'm having a serious issue with Premiere Pro and I'm hoping someone can help me out. After every cut I make using "Ripple Delete," Premiere Pro automatically saves the entire project 2-3 times, making it impossible for me to work on my project effectively.
I've tried disabling the auto-save feature to prevent this from happening, but it seems like Premiere Pro continues to save regardless. I've also restarted my PC and Premiere Pro, but the issue persists.
This isn't the first time this has happened to me, and I'm really at my wit's end because I can't work efficiently with this problem. I'm using Premiere Pro version v23.2 and working on a Mac Studio.
If anyone has a solution to this problem, I would greatly appreciate it. Thank you in advance!
