Premiere Pro crash error: "Your system has run out of application memory"
- 13 replies
- 3375 views
- Translate
I was attempting to open a project file in
Adobe Premiere Pro Version 24.5.0 (Build 57)
The project file is saved on:
Skandisk drive
Capacity 4TB
Available 2.09TB
Format ExFAT
The source files and the project files live on the same external drive.
When I unplug the drive from my editing partners MacBook and plug it in to my Mac mini to work on it. I get the following error before I am able to even view a loaded timeline:
"Force Quit Applications
Your system has run out of application memory.
To Avoid problems with your computer quit any applications you are not using."
The only application I have open is Adobe Premiere Pro 2024 (not responding) 99.03 GB
I was able to use Premiere Pro without it crashing when I was not using the drive.
The drive and the project file are not corrupt because they still work on my partners computer
My Computer:
Mac mini Apple M2
Ram: 16GB
GPU
MacOS Ventura 13.5
Storage: 245.11 GB
Available: 187.05 GB
My editing partner’s computer
MacBook Pro Apple M2 Max
Ram 32GB
Mac)S Ventura 13.4
Storage: 994.66 GB
Available: 933.64 GB
