Jul 6, 2024 10:32 PM UTC
Premiere Pro crash error: "Your system has run out of application memory"
I was attempting to open a project file in
Adobe Premiere Pro Version 24.5.0 (Build 57)
The project file is saved on:
Skandisk drive
Capacity 4TB
Available 2.09TB
Format ExFAT
The source files and the project files live on the same external drive.
When I unplug the drive from my editing partners MacBook and plug it in to my Mac mini to work on it. I get the following error before I am able to even view a loaded timeline:
"Force Quit Applications
Your system has run out of application memory.
To Avoid problems with your computer quit any applications you are not using."
The only application I have open is Adobe Premiere Pro 2024 (not responding) 99.03 GB
I was able to use Premiere Pro without it crashing when I was not using the drive.
The drive and the project file are not corrupt because they still work on my partners computer
My Computer:
Mac mini Apple M2
Ram: 16GB
GPU
MacOS Ventura 13.5
Storage: 245.11 GB
Available: 187.05 GB
My editing partner’s computer
MacBook Pro Apple M2 Max
Ram 32GB
Mac)S Ventura 13.4
Storage: 994.66 GB
Available: 933.64 GB
Carlos ZiadeCorrect answer
Jul 7, 2024 3:42 AM UTC
Based on RjL's technical reply, try to move the project locally and edit from there.
Carlos ZiadeCommunity ExpertCorrect answer
Jul 12, 2024 12:09 AM UTC
Hi @Stephen384591249ysd,
Thanks for writing the bug report. If the project is working on the more powerful Mac, then that may also be pointing to a performance problem. If you are editing a sequence with large frame-sized footage, like 4K or the duration of the sequence is on the longer side, that can also be a problem having less RAM.
We haven't heard back from you yet, so please let us know if you make any progress on the problem.
I am sorry for the issue.
Jul 6, 2024 11:42 PM UTC
Perhaps it's related to the quality control issues on all recent SanDisk external SSDs? These drives have a habit of failing due to a chip on the drives' circuit boards breaking off. And these drives cannot be properly repaired without wiping out all data.
