Premiere Pro Crash When Trying to Export, Click on Location
- July 22, 2022
- 1 reply
- 1992 views
Hello all! I've been having this seriously annoying crash every time I go to export a video. When I click on the file location link, Premiere freezes, and I have to evetually end the program task. This happens every 2nd or 3rd time I need to export. Everything else works fine. I also notice that the tool tip seems to struggle when mouse over the location link.
I'm on Windows 11 Home, PP 22.5 (also tried PP22.4) 64GB RAM, M.2 storage, Core i9-9940X, GTX 3090. All other software/firmware is up to date.
I noticed that with 22.5 you can actually see the files in the location that you select, allowing you to copy a file name to make it easier when exporting several files with a similar long name. 22.4 only showed the folder.
I wonder if anyone else is seeing this, and whether it's a Windows problem.
Cheers!
Luc
