Premiere Pro – Photo Time Lapse Issues
  • October 17, 2017
  • 6856 views
Hi all,
Today I took my first stab at creating a time-lapse video from still photos in Premiere Pro. I followed a tutorial which had me batch edit the photos (150 shots, to be exact) in Lightroom. I then imported them into Premiere and created a new sequence (0 clip overlap, 1 frame per still), but the video exported extremely choppy:
Does anybody know what happened and how I can correct it?
Chris
Correct answer Meg The Dog
This was just a test for my first time, but ultimately I'd be posting to web (i.e. Instagram, Facebook)
As a test, go to the menu File > Sequence.
When the New Sequence Settings pane opens, choose DSLR 1080p and click OK.
When the new (empty) timeline opens, drag your still images to the timeline. If you are prompted to match the sequence settings to the source properties, say no.
Your images may not fill frame completely - there may be black areas on the sides of the images - don't worry about this now.
Render the timeline. Does it playback smoothly now?
Export the timeline using the Format: H.264 YouTube 1080p Preset.
Does the exported file play smoothly now?
MtD
I think to get a proper time lapse, you need to shoot it that way.  Did you?
cmander36Author
Thanks for the response, Jim. Yes– I used the Time Lapse app that is built into my Sony a7ii. It was set up to take 150 shots at a 3 second interval.
cmander36Author
Go to Preferences > Media and set (if it is not already) Default Media Scaling to Set to Frame Size:
Now make a new empty sequence as you did before, Drag the stills to the timeline.
Move the playhead to the first still in the timeline to select it (you will likely have to zoom in on the timeline to confirm it is selected) and once selected go to the Effect Controls panel and adjust the Scale and Portion until it fills frame as you wish.  Once you have that set as you want, with the first still still selected, type Command (Control) + C to copy it.
Now select the reaming clips on the timeline ( a quick way is to Select All the clips, then holding the Command (Control) key down, click on the first clip to de-select it. Once the remains stills are selected go to the menu Edit > Paste Attributes and when the Past Attributes window opens, make sure Motion is checked and click OK.
Now all the clips in the timeline should have the same scale and position. Re-render to view, then export.
MtD
You were immensely helpful. I really appreciate all your quick and thorough responses!
