opacharly47
Open for Voting
Problem with "Digital LED LCD Clock Maker" template frpm Adobe Stock
I bougth the “Digital LED LCD Clock Maker” template from Adobe Stock.
Importing the module to the Time Line is ok. In the Effect Setting window, a couple of parameters like Font, Time and size settings appear and can be set.
But whatever the setting is: No clock function, no time count, only one fixed (frozen) display according to initial settings.
(tested with Premiere 2025 and 2026)
    opacharly47
    Of course I rendered and also exported the clip, but no clock function at all, just static display of the Starting Time set.
    Tried rendering the mogrt?
    Peru Bob
    Posting in the Stock forum might be best:
    https://community.adobe.com/stock-29
    opacharly47
    Thanks, Will follow your hint.
