Problem with importing iPhone movies (dish codec)
  • December 5, 2022
  • 12 replies
  • 2062 views
I've been experiencing problem I can't deal with. I am creating a movie from clips downloaded from my iPhone. All of my videos have codecs: MPEG-4 AAC, Timed Metadata and HEVC, but many of them have additional codec named 'dish'. I don't know on what it depends, but I can't import to Premiere Pro movies with 'dish' codec. What is the problem? How to fix it? My workaround is to turn them to side, side as *.mov file and then they can be imported to project, but they loose their HDR color range. Please help.
App version: 23.0.0 (Build 63)
macOS Ventura 13.0.1
Correct answer mayjain7130546
Hi @michalg42689863, @TVs Sean Bradley  ,
Sorry for this problem again. We have fixed it in the latest beta build.
Please check out the latest beta build version from the creative cloud and let us know how it goes there.
You can download the latest Premiere Pro Beta build from Creative Cloud --> Beta apps --> Premiere Pro (Beta)
https://helpx.adobe.com/x-productkb/global/creative-cloud-public-beta.html
We have also received a confirmation of this fix @ https://community.adobe.com/t5/adobe-media-encoder-bugs/import-movie-fails/idi-p/13337381
If you still face this issue, please share your media files(& project) here and we will check at our end https://helpx.adobe.com/creative-cloud/help/share.html
I hope it will help.
Mayjain
Thank you Kevin, it is odd! I was searching for an answer for long time but with no result... Here's an exaple of a video with this 'dish' codec. https://we.tl/t-aVXPjeVeqx
Hi michalg,
Wow, what an odd problem. Would you happen to have a sample clip you can upload so I can pass it along to engineering? We can test it here and get a bug written for you. Then, the team can fix it.
Thank you so much,
