Project Window Stuck Off-Screen. Any ideas?
  • February 10, 2018
  • 36 replies
  • 81309 views
-- I'm running Premiere Pro CC 2018 on a macbook pro 15" running High Sierra 10.13.3 --
I had previously opened Premiere at home with my dual monitor setup. Now I'm on the road and when project opens the top windows are off-screen:
When I select a different window arrangement, it gets worse:
I can drag the bottom of the window and resize it but I can't get to the top to arrange it.
Here's how I have attempted to fix it:
- Hooked up an additional monitor. When monitor is attached I can move windows, but the moment I unplug monitor, the windows go back to original off-screen position (no matter where I had placed them while add'l monitor was running).
- I uninstalled and reinstalled Premiere. Same problem as before.
- I restarted Premiere while holding the option key (to trash preferences). Problem still there.
- I created a new project. No change in problem.
Anybody have a good idea? Thanks!
Correct answer trashcaneron
Command+\ worked for me, just brings the entire app to take up the whole screen (in Premiere), easy. THIS is the correct answer. The answer that is marked correct requires you to delete your preferences which is totally unecessary.
I finally found the answer in After Effects. As when your adjusting the size of an image in Photoshop, AE works the same for the workspace. You hold shift+option when dragging from an edge & it resizes all sides equally. Fixed!!!
Mo Moolla
Window --> workspace --> reset layout. It will resize according to your native resolution
johnd1975
SOLUTION (MAC) :
-Uncheck your dual monitors in Preferences
-Shut down Program
-Restart program holding down the Alt key to reset preferences.
My window configs were also still there, only thing i had to do was reset my keyboard layout back to FCP7.
Hope this helps....
Telfer
Windows 10 Solution
I stumbled upon a shortcut that seems to fix the issue in Windows 10. The shorctut is Ctrl+\
It brings back Premiere windows to centre if they are off screen and further application maximazes the windows to full screen. From what i Gather this is not a premiere Shortcut - so must be a windows one - but strangely it works ony on premiere - it is not effective with explorer or firefox etc - so this is a bit strange. Can anyone check this out and corraborate?
command + \ for the mac! thanks!
Telfer
So it is a Premiere shortcut after all as it is cross platform. - I could not find it in premiere keyboard shortcuts panel but it works.
Given that I think it is safe to say that the solution to original post - are those keyboard shortcuts.
Windows - Ctrl+\
Mac         - Command+\
Hey all - There are a bunch of solutions for this problem that have been listed on this blog.  I discovered another one this morning that seems to be the simplest.
BACKGROUND;
I'm running CC 12.1.1 on a Mac Tower running Sierra 10.12.6.  I have 3 monitors with menu bar on the center monitor.  I keep my Project Panel on the Left Screen along with various other panels. Center is my Source,Program and Timeline Panels.  Right screen is my 'client monitor' along with other stuff.
PROBLEM:
When I open a new bin on the Project Panel by Double clicking, the top 2/3 of the window are off screen.  No amount of Double clicking on the panel, or anything else will reset it back on screen.  I tried some of the other workarounds listed above and while they work, they are a bit cumbersome.
SOLUTION:
This morning I discovered that if I move the program panel to my center screen and then open the bin, it stays on screen. Little bit of a bug, but a workable enough work-around that doesn't really mess up my flow too much.
Hope this helps.
thejorge21
[SOLVED] I have 2 monitors connected to my MacBook and I just ran into this problem today.
This is how I fixed it:
System Preferences -> Displays -> *go to the monitor that has the window problem* -> select "scaled" for display -> select an option with more space (make the display as high res [small] as possible).
This will shrink down everything on the screen, resulting in the premiere window to be brought down from above the menu bar.
jsolterbeck
Agreed, that would work providing your monitor had a higher resolution setting.  Unfortunately, my desktop monitors run at highest res.  Another user pointed out you could actually make the resolution smaller, and it would force the window to pop onto the screen fully.  But no matter what you do from there, even saving that as a layout, once you go back to your working resolution the bins still open off screen.
thejorge21
I forgot to add that once the window pops onto the screen fully, you need to resize it - I usually make the premiere window as small as possible - and then I change the settings back on my display and correct the window to it's original size.
Telfer
Windows workaroud I use is to open Nvidia panel - or windows monitor panel configuration - I find nvidia panel is faster for me to use.
1. Go to multi monitor configuration - I have it selected so when i open the panel it shows up on default.
2. Grab the affected monitor and pull it in the needed direction - then apply (if your Premiere window went up - pull the monitor up - you have to eyball the needed push ammount
2. After applying - the upper section of the premiere window should be visible. grab it and move it back
3. As this operation should take aprox 5 second , the popup window for permanently applying monitor layout changes should stil be up - click "no" and you monitor layout configuration goes back to normal.
Basicaly whenever You change the layout of  your monitors, every premiere window (exluding primary monitor) will stay glued in one place and not adjust itself to new layout.  Pretty annoying behavior.
Also, at least in windows - secondary premiere windows do not have buttons to minize or maximize. So the very usefull win 10 feature of draging windows into corners (or up) and docking them accordingly does not work for premiere's secondary windows. I can only speculate that those things are conected and this is not just a bug but something that premiere's code just cant do for now. That is automatically adjusting windows when layout or resolution changes and minimimizing and maximizing windows on the fly.
jsolterbeck
Is OSX, you can often double click a window anywhere, and it will do something.  Get smaller, get bigger, something.  In Premiere, this is also semi-true of the off-screen windows: when you double click it on whatever part of the pane is visible, it will resize.  The only problem is, amazingly, it won't resize the top.  It just resizes the rest of the window to fit the monitor and leaves the top bar out of reach.  So it clearly knows you're trying to resize the window.  That's maybe the most infuriating part of the whole thing for me.
For Mac users:
Go to System Preferences > Display  and set the smallest resolution (as image below)
It will set the all windows smaller so it is easier to see the bottom
jsolterbeck
This is accurate, except you wouldn't actually stay at that resolution to work.  So as soon as you switch back to the resolution you actually want, it just moves the window off the screen again.  Unfortunately it doesn't leave your bin at that new location.
For me changing the resolution then changing it back reset the window to how I wanted it. An easy fix after all.
Lach
leeca77 Changing the main screen didnt help me but let me to this trick:
1- Go to System Preferences
2- Lower the resolution of the screen (A) that hosts the off set window
3- You should now be able to see the full premiere window (i was)
4- Move the off set window to the other screen (B)
5- Reset the resolution of the screen (A)
6- Move the premiere window from screen B to screen A
7- Re-Save your workspace
This was the best solution I've seen.  At least with this, I don't have to use one workspace to open bins and another to edit.  Thanks.
using Ae and 3 screens on MacBook, pretty busy studio need multiple screens, and this stupid bug happens, tried fix around no luck fix it @Adobe,
Actually, I've found that changing the main screen on the mac, System pref>Displays, stops it being an issue with Ae, ni hope that might help others as a workaround
September 25, 2019
works for me every single time. much appreciated.
running macbook pro 15 (mid 2015), with two additional displays.
