Quicktime audio imports at half-speed.
Something changed. I used to be able to import quicktime .mov files into Premier just fine, and now it doesn't work.
The audio is perfect when playing the .mov in quicktime, but upon import into Premier, the audio is at 50% speed, while the video is at the normal speed.
I've seen this problem mentioned in various places, and the answer seemed to be to upgrade quicktime.
Well I've now upgraded everything and it still doesn't work.
What now?
Mac OS X 10.14.3 Mojave
Quicktime 10.5
Premier Pro CC 13.0.3
MacBook Pro (Late 2016)
2.7 GHz Intel Core i7
16 GB RAM
Radeon Pro 460 4096 MB
