AndrewTheGreat
Render and replace feature does not work with vertical sequences
  • March 6, 2024
  • 5 replies
  • 655 views
Hi, this may be a bug or a limitation of some sort but it really needs to be fixed. This is what I always get when I try to Render and replace a footage within a vertical sequence.
My footage here is horisontal and I'm trying to make it a vertical video for TikTok. As I understand Premiere Pro cannot render a horisontal video if it's used in a vertical sequence and this wouldn't have been a problem if Premiere Pro could Render and replace Nests but it can't either. So is there a solution or may it be fixed in the upcoming updates?
AndrewTheGreat
Hi, @Kevin-Monahan Seems I cannot reproduce the issue in 24.5
Stop trying to edit and EDIT!
Adobe Employee
July 23, 2024
Hi Andrew,
We've reported this to our product team to get it checked. We will keep you updated.
Thanks for your patience.
Sumeet
Hello Andrew,
Thanks for the bug report. Can you provide the team with more info? See, How do I write a bug report?
I hope the team can help you soon.
AndrewTheGreat
None of the formats works
Same problem, needs to get fixed asap
Adobe Employee
July 19, 2024
Hi everyone,
Sorry about the poor experience. We will get it checked. For Render & Replace, have you tried QuickTime Format with Apple ProRes 422 preset to check if it's working properly?
Sumeet
Same problem here, that's so weird
