“Review with Frame.io” Not working
- 29 replies
- 4951 views
- Translate
Hi everyone,
my team and I switched from Wipster to Frame.io because we found the native integration in Adobe Premiere Pro very useful. However, since the update to Frame.io version 4, the connection via “Window → Review with Frame.io” has stopped working – and this has been an issue since November.
I initially hoped that the problem would resolve itself when we updated to the latest Premiere Pro version in January, as we do every year, but unfortunately, it didn’t. Additionally, it no longer seems possible to downgrade Frame.io once it has been updated.
Frame.io now suggests using an external plugin from the adobe exchange website (https://exchange.adobe.com/apps/cc/202297), but it has received very poor reviews. After testing it ourselves, we found that CTRL + Z no longer works after installation – and I think nobody can live without that. 😉
I also attended an Adobe event in Cologne last week, where I was advised to seek help here in the forum. Has anyone else experienced this issue or found a solution?
Thanks in advance!
