Feb 3, 2025 4:15 PM UTC
“Review with Frame.io” Not working
Hi everyone,
my team and I switched from Wipster to Frame.io because we found the native integration in Adobe Premiere Pro very useful. However, since the update to Frame.io version 4, the connection via “Window → Review with Frame.io” has stopped working – and this has been an issue since November.
I initially hoped that the problem would resolve itself when we updated to the latest Premiere Pro version in January, as we do every year, but unfortunately, it didn’t. Additionally, it no longer seems possible to downgrade Frame.io once it has been updated.
Frame.io now suggests using an external plugin from the adobe exchange website (https://exchange.adobe.com/apps/cc/202297), but it has received very poor reviews. After testing it ourselves, we found that CTRL + Z no longer works after installation – and I think nobody can live without that. 😉
I also attended an Adobe event in Cologne last week, where I was advised to seek help here in the forum. Has anyone else experienced this issue or found a solution?
Thanks in advance!
JonesVid
Feb 6, 2025 9:32 PM UTC
Glad I spotted this post. I've just finished editing and producing a final export ...about to use Frame.io and not there in Premiere window anymore.
This explains it as Frame.io invited me to upgrade to version 4 end last year which I did. NOw I'm stuck like everyone.
This is not a good story and needs sorting out, particularly as I see the Adobe Exchange extension gets 1 star reviews.
I'll also raise a case I think.
Feb 5, 2025 7:40 PM UTC
Just an FYI, version 4 doesn't use the "Review with frame.io" Panel. It's a broken peice of software that I can't belive made it out of beta testing. You access it now by grabbing the "Frame.io V4 Comments" extension in Creative Cloud.
Feb 4, 2025 1:05 PM UTC
Hi @R Neil Haugen,
Yeah, I’ve noticed similar issues. Unfortunately, downgrading to V3 isn’t an option anymore, which makes things even more frustrating. I will open a case with Frame.io, and I’ll update you as soon as I hear back from them.
Best regards,
Jenni
andrew28092423tdkc
Aug 12, 2025 4:00 AM UTC
It is now October and guess what. NONE of the features from V3 are working. Im having to find alternative software because my entire workflows where messed up on how I ran my business and at this point I dont think they are ever fixing it. yet they are still charging us the same price.
Feb 4, 2025 1:02 PM UTC
Hi @Rach McIntire ,
I’m using Premiere Pro 25.1.0. I believe this should be the latest version, except for the beta, of course. Thanks for the information! I’ll reach out to the Frame.io support team and will update you once I hear back from them.
Best regards,
Jenni
Feb 4, 2025 12:58 PM UTC
Hi @Kevin-Monahan,
Thank you for your quick response. I haven’t opened a case yet, but I will do so right away. I’ll get back to you once I have more details.
Jenni
Feb 3, 2025 8:42 PM UTC
Hi @Jennifer_Lo97,
Thanks for the report.  What version of Premiere are you using?
The Frame.io support team will gladly assist you.
Please go here for help. If you have time, let us know what they say.
Feb 3, 2025 4:46 PM UTC
Frame v4 has been problematic for a lot of users. V3 works as expected, but in V4 people have had issues with getting logged in correctly, let alone the other stuff like they can't get the comments made by their client to show in the Frame panel or at times on a timeline, things like that.
Feb 3, 2025 5:37 PM UTC
Hi @Jennifer_Lo97,
Thanks for the message. Your case looks very frustrating. Do you have a case open with https://adobe.ly/3Q4hivo support yet? You can contact them here: https://adobe.ly/3Q1mkZt. Feel free to PM me any case number, or details you would like me know. I hope we can help you find a solution here. I find it unacceptable that a shipping product that you are paying for needs to work as expected. I apologize for this situation.
