Serious Performance Issues with Premiere Pro (14.0)
  • February 24, 2020
  • 59 replies
  • 12323 views
Hi Everyone,
I'm finally reaching out to this community as surely someone else must experience similar performance issues as me with Premiere? I don't want to give up on Adobe, but it has just came to a point where their products are complely unusable.
Long story short, premiere struggles BIG time with even displaying a fluid timeline, with no effects, scaling - NOTHING applied.
The crazy part is that I just tried a AMD 5700 XT card instead of my GTX 1070 - and it's no difference at all..
CPU 100% and GPU 0%
My spec
  • i7 @ 3.8ghz
  • 32 GB DD4 Ram
  • SSD
  • Nvidia 1070 (tried AMD XT 5700)
I also tried wiping windows 10, fresh install with only Premiere installed
Anyone has any ideas?
NATHAN - SHOTCUT
Adobe is not understanding this isn't a computer hardware or drive issue. There is something seriously wrong with PP2020. None of these issues were present in PP2019 running the same footage. The thread I posted has the exact same issue with the same complaints all from professional editors.
I have just read your posts, I'm 100% sure now that it's related to PP and not hardware or OS - I run Windows and you run OSX.. Exactly same issue..!
I tried downgrading to 2019 PP, but actually have exact same issue there
NATHAN - SHOTCUT
I knew someone else must experience the same issue, YES!  I can confirm ALL media is playing perfectly in the source monitor, but not on timeline..!
Tobiq,
Sorry for the frustration. Looks like some terrible performance going on there. Do you have the GPU engaged in Project Settings?
Your computer sounds OK spec wise but what about the rest of your system, like media drives? How are they connected? Internally, USB3, or Thunderbolt?
Do you have your .mp4 media on media drives? That's not normal for a standard NLE system. I recommend that you need 2 SSDs at a minimum, one for your OS and one for your media. Your performance will be far greater once you do that. If you really want to skyrocket performance, get a third SSD for your media cache. You'll be glad you did.
Have you tried proxies or transcoding your footage? In my opinion as an editor with years of experience: 4K H.264 or HEVC is the mark of the devil and must be dealt with before you start editing with it. I prefer to transcode to ProRes LT. You might try it.
NATHAN - SHOTCUT
Same issue as me Kevin...
Jeff Bugbee
This icon indicates a problem. Can you click and it tell us the error message?
